Why not try some HV caps & bypass with Russian Ky40 caps Merlin ? You might get something similar. I played with the Ky40 & there’s some BG sound to it. Another option, is to look for low value BG like 10uf HV caps & parallel them with other caps. I bought a bunch of 250v 10uf caps from Micheal Percy, not sure if they still have stock.
Cheers
I used Jensen PIO bypassing big lytic caps in PSU and don't like it. I like the 1/10 value of Auricaps bypassing the big lytics in HV PSU.
wow hot on the herls of black gates.
Lot of 4 Genuine Elna Cerafine 500V 100uF + 100uF Capacitors same Black Gate WKZ | eBay
100% it's F&T.
Luke, you're very astute. I wonder why no one else has picked up on that. How can a tiny British HiFi brand make money from a product that a huge multinational couldn't?
I can't help but think that they will get a big run of a few values that will sit on shelves for years. I prefer to buy fresh caps.
About the polyprop tubecaps there is no doubt. Have a bunch of F&T Joule caps 20/750v and they sound pretty much identical. Look identical too.
As for other makes...have a few high voltage Rifa, hesitate to recommend them. Similarly with Felsic, but unlike the Rifa these have at least an excellent midrange. Also have some Kendeil which are just horrible.
Perhaps Siemens/Epcos/TDK are worth a try.
Just arrived Kemet 820uF 550V, attached pics and datasheet.
Thats about what my car is worth Actually now that I think about it, I would rather have the caps.
It will be interesting if you share an opinion. What are you comparing those to?
My experience with low voltage caps from the same series was deeply negative, but that means nothing.
The Kemets used by Rod Coleman!?
http://www.diyaudio.com/forums/tubes-valves/151421-26-pre-amp-226.html#post5251836
Mine 14,73€ unit, Rod's 20,36€ unit at Farnell https://es.farnell.com/w/c/componentes-pasivos/condensadores/condensadores-electroliticos-de-aluminio/condensadores-electroliticos-de-aluminio-con-terminal-de-encaje-a-presion-tornillo?brand=kemet&capacitancia=820uf&tension-nominal=550v&range=inc-in-stock|exc-delivery-surcharge
HV Kemet are very very good.
For LV I used Jensen 4 pole but I like more the BG and second Mundorf Mlytic AG+
For HV the best are BG, Elna Cerafine aren't bad but can't compare vs BG, still searching the substitute.
Hi , for LV power supplies bank I use the Supertech 4TTN (4 taps) with excellent sonic results across the audio spectrum. They are musical and have guts in current drain (4700uf /63V ---> 8A rms @120Hz ripple current). I have already supplied a big bunch of them, enough to turn them heritage to my kids
- Design & Build
- Parts
- Black Gates Going for Nuts $$$?
