BK-16 Folder Horn - Change Dimensions
Considering building the BK-16 folded horn. This is my first diy horn. Looking at making the cabinets a little slimmer and taller, by an inch or two. Will compensate for reductions in the cabinet widths with height increases. The Vb won’t change and area openings of the throats & mouths will remain the same; however, the mouth opening dimensions will change a bit. Is this OK?
To be honest, look for another design. From memory, the horn path is a bit too short.
