Considering building the BK-16 folded horn. This is my first diy horn. Looking at making the cabinets a little slimmer and taller, by an inch or two. Will compensate for reductions in the cabinet widths with height increases. The Vb won’t change and area openings of the throats & mouths will remain the same; however, the mouth opening dimensions will change a bit. Is this OK?
To be honest, look for another design. From memory, the horn path is a bit too short.
Not really. The cross-sections and length of the horn need to remain the same.
What driver are you intending to use?
dave
dave
ZillaSpeak - Speakers
I built these years ago and thought they had a hollow sound. But they did have a dynamic sound too which got me interested in back horns.
Godzilla
Godzilla
Dave, thanks again. You sparked my interest with the Austin A166s. Some folks apparently use the FE168ES with it. A good choice? Also, are you aware of any more recent plans available for it?
- Full Range
- BK-16 Folder Horn - Change Dimensions
