*BIG* Audio Toroidal Transformer
Toroidal Transformer for High Power Build
Originally From a 1000W Subwoofer Plate AMP
1000VA
115VAC or 230VAC primary winding
Secondary 1: 97.8V - 0 - 97.8V
Secondary 2: 0 -19V
Secondary 3: 0 -19V
~5" Dia, 3.5" Tall
Weight is about 14 lbs.
Includes mounting plate.
Note; The output voltages could be cut in half if 115VAC were applied across the 230V primary winding.
I can also throw in the rectifier / bulk cap board that provides +/- 140VDC, and a 12VDC keep-alive. Bulk caps are 2200uF 200V
Asking $50 + shipping. USPS flat rate should be $15 or less to USA address.
