I never paid much attention in those classes where they talked about transformers when I was going to school, I'm an RF engineer. I went to engineering school after I became an engineer! That is why none of my home made transformer experiments worked very well.
I was all set to order a pair of the big Hammonds from Angela Instruments (on their web site for $222 each), and get down to building "the big one" the old fashioned way. I tried calling them every day last week, and they were closed. When I got through today, they said that they had none of these in stock, and weren't going to order any more. Well, back to the drawing board.
I know that my mosfets were blowing up because of "shoot through". This was because of dead time issues, and the fact that my P channel fets that had far less gate capacitance than the N channel fets (H bridge). I was using parts that I had about 4 years ago, which were several years old at the time. This may work much better with some modern fets. I just haven't had time to play with it.
The basic concept of the circuit that I used is on my web site in case any of you get the urge to make some smoke!
http://www.tubelab.com/SSopt.htm
Got me thinking about pairing up my GU48 with one of my 813s and my homewound toroid, maybe without very high volts. Watching with a great deal of interest these couple of threads and the results of the 2A3/6V6 combination.
Great stuff!
Mike
Great stuff!
Mike
Since this thread popped up again, I'll just put some references here to later threads on related subjects:
http://www.diyaudio.com/forums/show...107#post1446107
http://www.diyaudio.com/forums/show...781#post1597781
Hello,
those links do not seem to work.
- Elias
- Elias
smoking-amp said:Since this thread popped up again, I'll just put some references here to later threads on related subjects:
"those links do not seem to work."
Hmmm, copy edit didn't work for some reason. Here's another try:
http://www.diyaudio.com/forums/showthread.php?postid=1446107#post1446107
http://www.diyaudio.com/forums/showthread.php?postid=1597781#post1597781
Just adding another reference link to the later threads on anti-triode:
http://www.diyaudio.com/forums/tubes-valves/151220-spud-schade-pp-anti-triode-ecl86.html
and:
http://www.diyaudio.com/forums/tubes-valves/149674-my-version-simple-el84-rise-anti-triode-10.html
and:
Arrrgh, that last one should be:
http://www.diyaudio.com/forums/tubes-valves/149674-my-version-simple-el84-rise-anti-triode.html
- Tubes / Valves
- Beyond SET and ParaFeed.... Complementary Current Triode
