looks good from 1.65khz, still the whopping 7-10db dip at 15.5khz
+-1.5db from 1.6-10.6khz
Looking good for crossing from the m5n12 faital at less than 2k
I was planning to cross actively between bass and mid then use a passive crossover to the tpl, but may make it three way active.
enzo
enzo
Can you please post pictures of the horn? BTW, if you attach the pictures as "attachments" I can see them from any device. The way you are posting now I can see them from my phone, but not from my work computer.
Can you describe your measurement approach? You seem to be using REW. What mic? Are you measuring in-room? At what distance from the mouth? What kind of gating are you using?
Have you measured the Thiele-Small parameters of your drivers?
I just purchased my M5N12 and waiting for them to arrive. It sounds like your horn is a lot like what I have in mind for this driver.
i tried again at a higher volume and more on axis which gave better results, apoligies for my ineptitude, seems depending how you measure you can get whatever result you want!
measured using minidsp umic-1, at 1M on axis, signal from E-mu 0204 into 4p1l SE amplifier, transcendar opt. horn is sat on 50 x 50 x 95 cm back loaded bass horn in a 4 x 8m furnished livingroom, carpets etc i'll try and get pics.
[/IMG]
- Beyma tpl150h modifications?
