Belin have send me the graphs, so I'll post it here.... Black curve is on axis, red is 10º out of axis, green 20º out of axis, blue is aproximately 30º out of axis, The second black in the upper graph is the response
with more than 45º out of axis.
New measurements
Hi all,
I'm working (I must say not much) with new measurements. The time window is now reduced to 2.5 ms aprox. The project is going really slow, but I don't have enaugh time to spend in hobbies. I'll post the graphs of the tweeter and woofer responses in next messages.
Hi all,
Hi Belin!
How is your project?? Some new findings? I'm still deciding whether use this driver in my next project or not...
Martin
Martin
Hi guys!
I've been asked to build a filter for this driver by a friend of mine.
Any news on this project?
How did that filter indeed turn out Belin?
And what did you do with the drivers in the meantime SumacSK?
Hi, I just finished a pair of bass reflex boxes (60lt) and I am currently using this crossover
Suggestions?
Thank you, Andrea
Suggestions?
Thank you, Andrea
Yesterday evening we made some listening test with a friend and they are not bad at all. Maybe it is better to increase the first capacitor 2,2uF to 2,6-2,8uf (it seems to be better).
I have also changed the resistor (in parallel with the tweeter) from 1,8ohm to 3,3ohm, but in this case there is no audible difference.
You can see the speakers here: http://www.audiofaidate.it/forum/topic.asp?TOPIC_ID=2819
When we will measure the response, I will post the results.
Ciao, Andrea
Ciao, Andrea
I never managed to buy them.. I ordered them but then they told me that this speaker is out of production.. I don't know.. 🙁
Natali: that speaker looks good..
You can see the speakers here: AudioFaiDaTe.it
Ciao, Andrea
hello Natali
would you post your crossover again?
- Full Range
- Beyma 8BX
