better polystyrene of the two
here we go. the first pic is for 220pf but i'm after 33pf and the circuit, miniref, where i'll be using them can accommodate both 33 and 22 tho with better distortion/worse stability trade off.
It is difficult to tell outright from the pic, or even the spec sheet: in general PS caps are OK, but I have measured a number of counter-examples, even from manufacturers you wouldn't think are questionable.
Anyway, unless you intend to use them for power applications, it doesn't really matter.....
I can't tell from the pics, but I'd probably go with the radial lead ones, rather than the axials. The radial lead, copper foil ones (Noble?) have been OK. Evox/Rifa PFE225 and a Philips KS, both square cross-section box types, are also very good, as are ERO KP1834 and KP1835.
