Best Input differential configuration in amplifiers.
All guys are pouring the differential designs from every corner of the world, but wait a minute could you all please tell me "Which one is the Best differential"
The boring answer to that question is: best for what??? They all have their uses and their pros and cons.
I like to go with as simple as possible for a certain funktion and maximize the circuit by using the right amount of current,local feedback and so forth.
Circlomanen, look at your Silly way of answering the question, which I think you dont even figure out what to ask for or what to say for it. maybe you dont know the answer. Dont worry other guys here would help me.
i again repeat"what would be the best differential to be implemented in amp circuit"
Im sorry if I offended you in some way, Im not trying to make fun of you or anything. But the answer is still the above. There are a million ways of building an amp and they are good at a million different things, soo, you are right! I dont know the answer to that question. I wish I knew! Than i would imediatly start a company producing amps. A normal simple diff pair is very good in many ways but not the absolut in lowest distortion, a more complex version can have a lot less distortion but not sound better anyway, and complex circuits often need more caps and stuff to make them stable and good behaving. I myself like CFP circuits because of the stability. they very rarly need any millercaps or any other kind of frequency limitation to be stable and yet they often offer very high bandwiths and high speed.
Transformers have a lot of good sides to, but they are not that popular.
If you specify the intended use, it will be a whole lot easier answering your question.
Johannes.
My favourites would be the ones the attachment. The one on the left is the simplest symmetrical LTP possible.
Circlomanen is right though, there is no single 'best' configuration. All have strengths and weaknesses that make them more or less suited to a variety of design goals and philosophies.
amplifierguru said:
Hi Fab,
Just joking. "How may devices does a front end need..." ( to the tune of "Blowing in the Wind" Bob Dylan). But you forgot the IDEAL current source - surely that's good for at least 2 BJTs and a cascode.
Hi amplifierguru,
some peoples prefer a simple resistor for current source but I can not figure why (electronically speaking). Last one I used was 2 bjts with one resistor in series (in lieu of cascode bjt).
How to choose the suitable transistor for differential? One guru here said to choose one with big hfe.
Assuming max voltage and max dissipation is not a problem
MPSA06 Hfe=100
MPSA18 Hfe=400
MPSA42 Hfe=25
2N5551 Hfe=60
BC550C Hfe=420
The lowest Hfe is MPSA42, the highest is BC550C, which is the most suitable and most not suitable for Differential? And for VAS?
Yes I'd be inclined to agree with that for a commercial product Sam. But DIY has different rules - and high beta selection can be a simplifier so choosing from a group different hfe for different roles is a viable option.
I have a design nearing completion (150W/8ohm monoblock) which uses 5 pairs BC546/56 - some for regs,some for cascode, some for gain AND some for DRIVERS! I can select hfe ranges for each role and the reg or cascode comes well down the list so all devices are used 'gain'fully.
AndrewT said:
Hi Mr Evil,
is that your bootstrapped cascode?
Could you produce a paper / wiki on the design process to arrive at the components around it to suit a set of input/output conditions?
It's just the normal way to use JFETs as cascodes, as commonly seen in cascoded current sources. A resistor between the two tails sets the tail current (calculated in exactly the same way as for a JFET current source) and then it's just like a normal LTP, with gain and output DC level determined by the load resistors.
Workhorse, bad attitude. :bawling:
I agree with Circlomanen, simple seems to be best.
You're supposed to be the PROFESSIONAL Audio man, why don't you tell us your PROFESSIONAL answer. 😕
(; gnikoj tsuj
And here we go... 😎
Go ahead and use it Kanwar, your amplifiers are going to be superiors and make a breakthrough, with this diff stage you don't need to bother anymore, but don't ask me for permision because I am the wrong person to do so! 😉
Cheers 😀
I would appreciate constructive feedback on symmetrical folded cascode front-end circuits similar to the attached +/- 12V schematic. Low noise and low distortion, espeically for the first watt are most important. Fewer transistors often translates into lower noise. Improvements to the basic design welcome.
Matching transistors is a challenge for small quanitity DIY purchases, so I tend to use dual transistors and purchase binned parts. Thermal tracking is also much easier with duals.
