jackinnj said:National Semi recommends polypropylene
As PSU bypassing polyester should be fine, although of course poplyprop are better caps.
jackinnj said:-- see also the Capacitor Distortion thread -- I ordered a bunch of polypropylene caps on Friday, so we will see. I happen to think that the Xicon polyethylene terephthalate caps are pretty good ---
I've read that thread some days ago, very interesting.
Very curious about your findings, although of course it will be hard (and $$$) for you to test all the caps you would like.
I agree with Carlos about polyester cap for PSU.
For me, I usually prefer MKP type for bypassing cap and coupling cap.
gengcard said:I agree with Carlos about polyester cap for PSU.
at least at EPCOS MKP and MFP are polypropylene.
http://www.epcos.com/excelon/servle...aetter.xsl&lang=e&gr=CAP&sub=FC&prgr=PG_FC_PP
jackinnj said:at least at EPCOS MKP and MFP are polypropylene.
They usually are.
Do you guys have experience with Siemens MKP?
These caps have a vice of removing the highs.
Even using a 100nf cap to bypass a bigger one "smooths" the treble no end.
On the signal path, stay clear of these ones.
I didn't have the courage to try them as PSU bypass.
Sincerely, Philips MKT (polyesters) are much better...
carlosfm said:
They usually are.
and what analytical method did you use to arrive at this conclusion?
jackinnj said:and what analytical method did you use to arrive at this conclusion?
I just take a listen and don't like it at all.
I tried 100nf bypass in parallel with 4.7uf poly on the output of a preamp.
Treble smooooths as soon as I put those Siemens MKP.
I also tried Siemens MKP caps on my Epos ES11 speakers (on the tweeters) and transformed a good speaker in a cheap boombox.
Two days after I removed them and put back the original caps.
What do these caps look like? I remember i used to use Siemens MKP B32650, blue in colour and they were not really that bad. Then again, it was around 1985 so maybe my tastes have changed a bit 🙂 They were at least as good as WIMA MKP and way better than any MKT. Should i dig them out and give them a listen?
Do yourself a favor and keep tantalums out of audio circuits! They are no good for audio signal path and no better for ps use.soundNERD said:How about film, glass, tantalum or Niobium Oxide caps??
'Film' is a generic term for lots of type of dielectrics like polyprop, polystyrene, mylar, etc....
Glass is usually mica and not real glass and is only good for small pF values at high voltages.
I find polystyrene to be the best in values under .1uF and polyprop above that just from my own listening and experimenting.
analog_sa said:What do these caps look like? I remember i used to use Siemens MKP B32650, blue in colour and they were not really that bad.
A quick google search didn't produce results, a pic would help.
They are rectangular with clear plastic case and the legs are at the sides (the legs are soldered on the extremes of these caps).
I have some that are non-isolated, others have a blue plastic coating on the sides to hold the legs.
On the non-isolated version care is needed when soldering, or the legs fall apart
Isolated or non-isolated, they are exactly the same caps.
I have a few examples of 2.2uf, 1uf, 0.47uf and plenty of 100nf.
BTW, they don't say Siemens anywhere, but I was told several times that they are Siemens.
I think this construction is called 'stacked film'. I also don't like them. Sure they are MKP?
Carlos, little bit off topic question : are you using fuse on secondary winding in every PS ? By the shorting on DC side, which fuse blow faster, on primary or on secondary ?
analog_sa said:I think this construction is called 'stacked film'. I also don't like them. Sure they are MKP?
The 100nf caps only say "u1 250", nothing more.
I think these are MKP, but not completely sure.
Yes, these may be 'stacked film'.
I've been using ERO MKT with good results, and in some places in a circuit, I actually prefer them to BG, like for instance bypasses on TDA1541 😉
Peter Daniel said:I've been using ERO MKT with good results...
I have some of those, not bad at all.
Light green colour.😎
The Seimens/ now EPCOS Capacitors discussed are as follows-
1. The clear coated caps described by Carlos appear to be MKT B3256x Uncoated (silvercaps) which are stacked film polyester radial capacitors.
EPCOS also make the MKT B3252x MKT and MFT (mostly) stacked encapsutlated polyester radial caps.
They also makes the MKP 3262x stacked polypropolene encapsulated radial caps.
All of these have very low inductance and might be appropriate for ps bypassing, zoebels, etc....
http://www.epcos.com/web/produkt_katalog/html/film_capacitors_e.html
The ERO/Vishasy caps often discussed for signal path bypass are the MKP1837 metalized polypropolene radial caps and KP1830 polypropolene film and foil radial caps; generally in values of 10 to 22nf....
http://www.vishay.com/capacitors/film/polypropylene/
FWIW
FWIW
But that's a polyester type. Siemens stacked film types are only good on a different type than the one Carlosfm described.
The transparent body type was no good, but there's a Siemens type called MKT, blue bodied, which is very good. Panasonic stacked film types are also quite good, at least for bypassing.
For series connection or filter, not many beat polystyrene or polypropylene types.
Carlos
- Chip Amps
- Best audio cap
