Ok for nickel /brass
Our noise circuit was finalized...(active). In simulations we get 40-50db in 0-20Khz, about 30db at 100Khz and 20db at 200Khz.Of course we have also passive filtering (LC).
We are pretty sure to have excellent noise specs output and input (mains)
If you want tor reach "Best" cable and connector, it should be nano tube carbon. it conduct like copper and acid resistant as glass, also strong as steel. gold are soft.
If you say so. That's the reason I said to keep it DIY-friendly. This way we all can use our
own favorite wiring - just in case.
Price/Performance ratio will be one of the key aspects. For now Allo has shown to
come up with good quality products at reasonable prices without using boutique parts.
From my perspective I think that's a good approach.
Yeap I think we will skip the nano tube cabling...
One issue we have, is that mold manufacturer is saying that plastic casing has to be glued. So customer cannot open. I think its best to get the cables correct from the start.
I don't see a way to open it.
Ok. That's the same issue I have with the iPower.
A jack and/or a screw terminal right at the PS (without any cable) might be the best option to avoid
destroying the case. You'd just have to add a separate cable to the box.
1. Don't forget that the "numerous" cable parameters matter big time This plus the right choice of plugs might have ten times more impact than your observed oscillations.
2. A good balance of risetime plus current delivery has to be found Overregulation, overdamping/-filtering, high ESR, low buffer capacity might be some of the things to eliminate as much as possible. I fought this by adding low ESR buffer capacity to the iFi.
Are you serious about this? In case you are I'll comment on that content.
One question...on our rectifier bridge we are thinking to add snubber to reduce the EMI.
Instead of using RC snubbber on each diode , can we use only one before the bridge ?
Something like this https://diyaudioheaven.wordpress.com/tutorials/power-supplies/snubbering/
I'm considering buying something similar to the Allo Boss DAC hat for the Pi and I need to buy 3 of them. Still unsure as it doesn't offer balanced output and this may be a necessity.
Whichever unit I buy, the 3 Pi's and DAC's will be in the same chassis and I need a 5V supply which is how I came across this thread... need advice.
I think I would like to go down the SMPS route and possibly looking at 10A? Unsure of the voltage yet as I'm not sure what regulation to use (Voltage drop etc). I read earlier in this thread that someone had tried an SMPS and LDO (TPS7A47) but was not happy with the result. I would have thought this would meet my needs if its efficient.
My questions are:
Do I split the rail from the SMPS and feed 3 low noise regulators (due to the current limitations) and then supply the Pi's which in turn supply their DAC hats?
Or is there a better way to do this? I know the Allo DAC has claimed good onboard regulation as have other DAC hats. I also thought that Pre regulating an existing good supply can have negative effects?
Also I've had heat problems before using LDO's as they often require very close Voltage matching (Input - output + Voltage drop) especially when running a raspberry Pi that may draw 500 mA
Any advice appreciated, but please don't advise 3 seperate wall supplies...
Stuart
My questions are:
Stuart
What requirements you are targeting in a 5V5A SMPS? How did you measure the noise / ripple?
Micro.
Micro.
... Seriously, 1uV in an uncommonly narrow bandwidth? When powering a high speed processor supplied by the cheapest on board buck converters possible? Who cares? It is not like that noise contribution is even going to be visible in the roar of non synchronised spread spectrum clocks and bucks on the CPU card. ....
Read slowly and ponder...
Great to see that you guys (@Allo) are working on a PS product. I hope this time a single voltage (e.g. 5V) device.
Some things to keep in mind:
2. A good balance of risetime plus current delivery has to be found Overregulation, overdamping/-filtering, high ESR, low buffer capacity might be some of the things to eliminate as much as possible. I fought this by adding low ESR buffer capacity to the iFi. 3. I'm not sure if a flexible DC cable length wouldn't have been a better approach on the iFi. Fixed length and then rather long DC cables are not what I'd call the ultimate solution.
4. And the other thing which IMO might not be the best of all approaches is to have the supply sitting right in the mains distribution block. I'd rather see it closer to the device.
5. iFi IMO has done a great job by supplying several uselful adapters. Something you want to think of if you intend to be commercially successful.
Just my thoughts (based on my experiences).
Looking forward to an iPower alternative. 😉
Good luck.
I'd also appreciate some green screw-down terminals for Vout
more questions..
What is this 5V psu , will output only max 1A but will have full galvanic isolation from the mains ? (noise extremly low, excellent impedance.)
Would that be better for most projects ?
I am thinking mostly in low noise hardware...DACs etc.
Our 3A project is still going forward.
This is another project. I am thinking that all dacs etc need 5V PSU and 1A is plenty . I think its most important to have galvanic isolation on those projects along with low noise,
It's not just DACs. It's also about SBCs and SBCs plus DACS and/or Kali and/or ....
1A just limits the scope of that supply. I wouldn't buy it.
iPower @ 2.5A IMO should be your reference. If you come close to it or even better it at a lower cost you'll have a product to sell.
Our PSU is being sent to PCB house for samples. 3A/5V
Funny thing is that as a side note of this project , we are also sending to PCB house a small 2cm/6cm PCB , that has an active filter for audioband frequency (50db) with common mode choke , differential noise inductor and 470000 uF of capacitance at the output . It will work up to 3A
- Power Supplies
- Best 5V SMPS ?
