I have 2 Nirvana's in my system 1 powering a Digione player(Pi 3B) and the other feeding a DAC (Topping D50). Very happy with them, but have to be careful with the grounding scheme. Best results with DC ground connected to PE, but with Nirvana's on a separate AC mains circuit and not both in the same 2 outlet receptacle. If they are in same outlet best scheme is one DC ground to PE, the other not, and even then not as good as on separate circuits. This is base on several long term listening sessions with the same familiar playlist.
Does the nirvana come with shielded cables AC & DC ? Are the detachable?
Looks like Allo Nirvana comes with same thin, long attached DC cable as on my Allo Shanti. At least Nirvana comes with a USB jack and some cable adapter/plugs, although they are flimsy as well.
Hi , Is nirvana 110v or 220v , If I buy from allo USA store ?
It is a SMPS so will take 110-230 V, as it's AC cable is hardwired you have to specify the plug type. If you are after a US plug version Chicago Electronic Distributors currently have them.
I see it on Amazon with free prime shipping, but it ends up at ~ same cost with paid shipping from Chicago. Its still better than international ship from Allo in India.
Some of the Amazon pics show a US 120VAC power cord, and others show what looks like a 240VAC version. Which version is being offered for sale?
Plug type is only for connection to local AC mains, it has normal voltage range of a SMPS. If you select the right AC plug type you should be fine. Amazon & Chicago EDistr. offer only US plug, other types you can get from Allo directly and will ship from India.
Small flimsy output cable
I really like my nirvana power supply, purchased from Chicago electric - prompt shipping and communications. It seams like a nicely built unit and good value for the money but for the life of me I do not understand why the dropped the ball on the last mile- the output cable. When all things settle down And warranty is not a problem I will have to replace it. At some point I will have buy a shanty and give it a try as well. I will also have to buy and build a Iancanaca power supply with his super cap board. I bet when all is said the shanty will be cheaper, but it will be nice to compare them.
Bill
Bill
I found that the output cable was better than using the USB connection with the usb to barrel connector that came with the DAC, so cables can make a difference depending on shielding/grounding schemes and how close DC cable is to AC cables. Star quad would be optimum DC cable, but that adds $$. Question for Allo is the connect ground to PE switch operational for the USB connector?
- Power Supplies
- Best 5V SMPS ?
