I don't use any parts I can't see.
Buy a micro scope or hire more younger people
I do it every day but I can't hire people. It's the soldering iron tips being to big I have trouble with
Yeah......but, will it blend?
http://www.spikedhumor.com/articles/126244/Will-it-Blend-Chuck-Norris.html
-chuck
-chuck
-chuck
no but I bet it floats
Didn't someone (maybe Tim de Paravicini) do this with 12AX7s?
Yes, that was realized at the EAR Yoshino V20 Amplifier from Mr. Tim de Paravicini. 10x ECC8*/12A*7 at each halve - go to
http://www.ear-yoshino.com/prodpics/V20_Integrated_Amplifier_t.jpg
http://www.walrus.co.uk/ear/v20.jpg
http://www.stereophile.com/integratedamps/1099ear/
http://www.diyaudio.com/forums/showthread.php?t=94403
http://www.diyaudio.com/forums/attachment.php?attachmentid=78488&d=1170054327
Also by the Krell MRA you will find large groups of paralleling semiconductors, go to
http://www.diyaudio.com/forums/showthread.php?t=3508
http://www.krellonline.com/krell_component.php?id=30&page=MRA
http://www.premieraudio.ca/uploads/images/MRA_Amp.jpg
http://www.stereotimes.com/event010101.shtml
I am very interested at your comments about sonic impressions, when this amplifier approach here is finished. Are there not such solutions as integrated circuits from Toshiba on the market (MET = Multi Emitter Transistor)? I mean not "Multiple Emitter Transistor" from TTL topology.
please read
http://www.freepatentsonline.com/3946425.html
the integrated circuits, that I mean, actually BjT power devices, special made for audio and internal multi emitter structure
I'm really looking forward to seeing the finished amp. What name would you call it? F1000?
No, F1176
Heat? I heard someone immersed some amp on oil...maybe vaseline, with its many uses , could also work.
Sorry guys, Seymour Cray beat you to it a quarter century ago. He solved his cooling problem by making the entire supercomputer CPU walk the plank into a tank of Fluorinert. *Sploosh!*
http://en.wikipedia.org/wiki/Cray-2
http://en.wikipedia.org/wiki/File:Cray2.jpg
salad oil will do
http://www.markusleonhardt.de/en/oelbilder.html
Variac and Elena and Jill and I all went to see Thievery Corporation at the Warfield a couple years back.
The performances were awesome but the sound system sucked.
Tosca / Suzuki
Have it on vinyl. However, the new tosca was very disappointing.
salad oil will do
Sooner or later, I figured someone would have come along who might want to discuss such things on these threads. I'll start by saying, Been there done that. Cray, Chippewa Falls, 3M Flourinert, etc. etc...
Saying "salad oil would do" does not make me wanna go look up the boiling point of salad oil, but did you get that nucleate boing thing from those links? Vasaline may be the same??? Flourinert that was used by Cray, and myself, cost between $350. and $550. a gallon (Then). Their phone booth looking CPU and my burn-in bath both used $20,000 + worth of Flourinert!!! I would have thought the educated dudes before me would have set me up with Vasaline if it was so easy??? Or, I at least would have seen a SOZ in Vasaline by now
If some here only new what all that was about
My biggest problem with that project would proably be the death of your amps performance (I have not actually tried an amp imersed). The nucleate boilng makes a noise (memory distortion like stuff) which would likely end up on the signal path???
salad oil will do
When it goes rancid you'll have a big pile of oxidized parts.
I think at the cost of the jfets and Mr. Pass's time that a couple of gallons of flourinert would not be a deal breaker.. if it is actually required. And only a couple of gallons would be required- those boards and their populations are not very tall... I also would think a liquid would be better than a goo because it can circulate, which should help with cooling quite a bit.
Isn't the idea to use lots of small capacity devices to get the needed power? I would think that with that your heat dissipation should be small per device and heat sinking shouldn't be necessary. I would guess that a couple slow spinning box fans would be perfect. Unless of course you were after a higher power version.
Synthese design amp along the lines
Pre and power amp : Brilliant One + Brilliant Direct
Arrays of TO92 BJT's, = not (J)FETs.
- Beast with a Thousand JFETs
