Bass boost in portable active speakers?
like the bass boost circuit you can include BSC correction in
the power amplifier feeback loop, in this case by adding a
resistor-capacitor in parallel with the gain setting resistor,
in the same way as shown in you circuit. There is no need
for another op-amp for BSC, but if one is already there.....
🙂/sreten.
yes, I'll probably only use one chip (LM1875) and use those speakers at home.
My initial idea, that battery powered Class-D version, I'll probably realize it a bit later.
time to start doing some more practical work now! 🙂
I owe you for the many times you pointed me in the right direction!
Dominique
