Yes I bought 100 devices each. From the German shop Reichelt they are quite cheap (but comparable from Mouser or Digikey in large quantities)
Security Check
Security Check
I used a 24 Volts lab supply and a 33 Ohms resistor screwed to the heatsink in the foto and the schematic according to Papas article. Slight variances in Vgs and hence current were adjusted by adjusting the supply voltage to give constant voltage drop across the 33 Ohms resistor. Also I used a fan and measured all in one go to have the same conditions. Attached you can find the results I got.
Security Check
Security Check
If your first build, and since store is selling Harrises, get ‘em. Papa matched them personally. Plus, if you only need 6 per side, buying in the hundreds will cost you.
That’s bot to say Papa does not make mistakes with matching, but can you do any better?
Those are matched close enough for 0R47 source resistors.
If you plan on macing bias, consider higher source resistance or jig them.
Or trust Papa the man
if shop is selling Harris, that's from Papastash
Papa's stash stash?
I would just use standard Pass 5% Panasonics @ 0R47, as specced. If you run into matching issues, post here and you will be helped. Also, depending a bit on speakers you use, 1R is perfectly fine. RusselC uses that on his sensitive speakers, and is very happy with that. 6L6 did too on the amp in the guide. 1R is the ubersafe choice, 0R47 is the specified for 3 deep config (6 transistors per side).
Regards,
Andy
Regards,
Andy
Maybe that came out a bit wrong. The blue-grey Panasonics are widely used in Papas designs, is probably a more correct statement
This one, I think: Blocked
Cheap and cheerful, like Dennis Hui always says
I am not the one to ask about «standard» Papa parts. I think he uses what fits the purpose and is good enough. He is more about active components, and there the J74/K170 JFETs are PL standard, as you prolly know allready
Edit:
MZM! Not nescessarily requring a full page, for a GH like me, a few key takeaways that never go out of fashion:
IRFP240
2SJ74
2SK170
Nichicon Audio Grade caps
Elna Silmic 2 caps
Claritycaps «For Pass».
Plitron transformers
No more, will be a page then…
Edit:
IRFP240
2SJ74
2SK170
Elna Silmic 2 caps
Ok cool, thanks! As a newbi, I'm looking for any guidance when picking between half a dozen identical parts for every spec slot.
FIRST WATT
This:
https://www.firstwatt.com/pdf/prod_f5_man.pdf
https://www.diyaudio.com/forums/att...08d1618428012-beyond-fringe-beyond-fringe-pdf
Also the «distortion and feedback», F5 Turbo, BA-1/2/3 and «leaving class A» are good reads.
List is not extensive, prolly many more are important…
Also, on the Passlabs website, the article about parts selection, he talks about «squeezing the lemon» of the IRFP9240s midrange irregularity/distortion in a non-feedback circuit, and there you have it: the F4 and BA-2 OS. No lemon on the Harrises though, so be prepared to get your sugar from elsewhere using those. P3 is the solution if a little H2 is your kinda thing
- BA-3 Amplifier illustrated build guide
