We were thinking of shipping a body bag over to BA.
You guys are required to check the temperature and USPS the thing back to Serbia before he starts to melt.
(I was informed, off the record, that ZM will be releasing the Stinky, the companion of the already introduced Shiny. After that, the BarF-What is scheduled.)
wackoo place - this Pass board
ya ppl nutz - seems that OT virus is spreading
anyway -
@Jaccovitty - I feel jeopardy ......... slight possibility that some terrorists can grab bodybag , and force me for good to keep my finger in dutchie tide fence ........
( I heard some sayings that in dutchland is harder and harder to find adequate wackoos for that job 😎 )
anyway -
I suppose the B1 case is a new standard issue series, the Key Largo for all the B-number offspring ?
(we're all becoming too fat for hard hole labor overhere, but you'd still be a tight fit dike plug)
dw8083 said:I just love this forum and the participants here.
Within an hour or two members started reverse engineering the B1 from Nelson's acute angled picture. The forum will have self-documented the DIY article before Nelson publishes it.
Prediction:
Choky will have a complete circuit and boards with customized improvements made shortly called the BBF (Best B1 First), or ABC Pre for "Another B1 from Choky" or something!
People here are simply great! Cannot wait for the upcoming BurningAmp in October again.
-David
Zen Mod said:besides fuglyness ..... interesting ...... input cap , output cap , comp. jfet buff as in Papa's Lightspeed , single voltage supply ?
less is more 😀![]()
You missed a couple of things. You can clearly see the 221r resistors, 9.1v zeners, 220uf caps, and 3r 3watt powder blue Pannys. After all, it wouldn't be Pass without it
Seems B1 is ever on.. so no need of the on-off indication..
Maybe, I'm too straight forward without applying joke or humor..
If so, my style must be grown by my serious job..
Anyhow, the holes should be filled in.. by the right ones..
Nelson Pass said:
I used the hole for the switch...
Yeah, the problem is when you want to put two things and have only one hole 😀 . So, the switch got a priority. No blue LED. Or, maybe, as the buffer is supossed to be the "invisible" piece in the signal chain, there should be no indication that it's there, no? 😀
Babowana said:It looks having two inputs:
(1) Passive pre with no buffer
(2) Passive pre with the buffer
and one output to the power...
I'd say:
(1) Passive pre with the buffer-with the volume control
(2) Passive pre with the buffer-without volume control. i.e. just a plain buffer.
P.s.
Jacco, I like these switches!
Vix said:(1) Buffer with volume control (2) buffer without volume control.
You don't need a switch for that, not at the front anyway.
Beeh, no fun with reply answers that fast.
Speaking of Buffy the Amp Slayer, you guys also have that back of your neck airflow notion-ness something that usually is, isn't lately ?
Only The Shadow knows.
jacco vermeulen said:Beeh, no fun with reply answers that fast.
ya crazy as rotten barrel , even I have major PITA to understand you this time ;
ya mean on GR ?
jacco vermeulen said:I definitely do not mean BL.
well - I definitely do not meant on Gray ......... or Violet ........ or Blue
(Grey ........... is that ringing a bell ?)
- B1 Buffer Preamp
