AVCC 2.1 vs AVCC SR
Dear All,
I still did not upgrade my DACs (Buffalo II) with the AVCC 2.1 that the AVCC SR is out. I was wondering if somebody can report on the sound difference between the two items. It's probably too early to say and I am wondering if there is any benefit in using the SR versus the 2.1 on the Buffalo II.
Davide
Yes, you will be pleased with the AVCC. I ended up using the standard 3.3 V Trident SR's before the AVCC (3.6V) came out, even with the lower voltage I preferred the (two) Trident SRs for AVCC, both on B-II and B-IIIse.
I find the ESS chips are very sensitive to power supply on the AVCC pins, even some small capacitor changes were audible.
I'm not home right now to take a picture (nor update the website 🙂), but here is a picture of some from "AVCC build day" a few weeks ago...
attachment.php
As you can see, they are wider, and the connector pins are onboard (same spacing as previous versions). They are really two complete Trident SRs on a single board.
Looking for the very same info. And even Trident 3 vs SR. Please include your system "revealing level", so we can estimate the level of SQ gain in our more or less high-end gear.
BTW still using old Placid supply here... set @5.25V when warm (5.5 cold with choke), is the gain on the AVCC-SR @5V higher than losses with Tridents shunt V3 (3.3 & 1.2V) @5V instead of 5.25V?
Yes the benefits of using SR are very much worth it - the SR has both lower noise and better PSRR. This is particularly important on AVCC - but it helps at all positions. It just sounds nice and clean - noise floor is bottomless. Shunt version of Trident was already very good in these respects - but SR is simply better. They also use less current - which helps your VD supply run more efficiently. In fact I highly recommend people try using the new LCDPS (with the new IC) when using high current demand modules like B3SE-Pro etc...
You won't be sorry you gave them a try.
Cheers!
Russ
Russ, no mistake with your low current supply for high current devices?
Btw, do you provide quality "inline pin header" (sorry don't know how to say) fort the 2x 4 pin on the Bxxx? And no start-up delay issue with any BII firmware?
Not sold anywhere in Europe? 20%VAT, import taxes...
Well, "low current" is relative. 2A is higher than 1A, but still lower than 5A 🙂
Not currently, but I guess I could add those in if people are interested.
There is a slower startup. I have not tested this on a BII, but I *think* a slow AVCC will be okay. Deferring this one to Russ who might know.
Nope, I build and ship them from here (USA) only. Sorry.
