AudioSector-chip amp kits, dacs, chassis
Hello, I've ordered the LM4780 kit. I'm planning on running it in two monoblocks. Does anybody have a suggestion for a good transformer? This will be my first build and I'm not very savvy to the pro's and cons of a good power transformer.
P.S. this is extremely addicting I'm having a hard time not ordering several of each kit. 😀
Thanks Peter for the quick answer to my "size" question.😀
I made it to the "big city" of Edmonton and wanted to pick up a copper "heatsink" at Metal Supermarket. I bought a piece so that each chip will recieve about a 3" by 2" by 1/4" "land" of copper. I'm still wondering if I need to attach an aluminum heatsink to this still?? I have plenty of old p4 cpu heatsinks around that I could attach. What are your opinions?
Also if I attach all chips directly to the copper heatsink without the thermal pad and keep the copper isolated from ground, would this work or do they have to be isolated from each other?
(The piece would hold 5 lm4780,three stereo,two parallel)
quick question about common mode choke for dac
Hey all.
I'm going to start purchasing components for the DAC kit.
Since I plan to build an external power supply, most of the PSU components will essentially be "off board", so I won't be hindered by size contraints.
In regards to the two common mode chokes, what is a suitable range of values/dcr for them, and what is the prefferred values ?
Same question in regards to the 1000uF capacitors (before and after the choke). Would there be any advantage to going larger ?
Thanks 🙂
The chokes are 0.6MH 3.0A , I guess anything similar will work here as well. My choices were based on the first Kusunoki DAC, I couldn't find a link anywhere, but whatever he used should work as well.
As to the caps, I like to use the smallest value suitable, that's why 1000uF only. You can try higher values (I was using 3300uF Elna Staragte too) but there was no improvement whatsoever, contrary, the type of the caps is more critical than the actual capacitance value. BG STD as first pair and BG NX as second work really well here.
If the chips are powered from the same supply, they don't need to be isolated from each other, providing the copper is isolated from the ground. And you will certainly need to attach more heatsinking to such assembly, as copper alone will not be dissipating enough heat. But, I would probably use isolation pads anyway, to avoid any RF noise pick up.
Re: Stereomojo amp shootout
ttan98 said:
Your comments because of your experience would be invaluable.
ttan98 said:
If you don't believe tweaking so then we may have agree to disagree.
nycavsr2000 said:
There is really not much else to do, except for fooling around with snubbers and perhaps the capacitors specifically on the amp board itself. BG STD 1000uf vs. BG NX 100 uf vs. etc...you could like one set with classical but hate it with rock. Too many variables, too many choices.
To give you idea how much tweaking went into the final Patek amp here is a link where I described my impressions with different capacitors and snubbers:
http://www.diyaudio.com/forums/showthread.php?postid=574431#post574431
http://www.diyaudio.com/forums/showthread.php?postid=581230#post581230
And here how I experimented with diodes:
http://www.diyaudio.com/forums/showthread.php?postid=134303#post134303
http://www.diyaudio.com/forums/showthread.php?s=&postid=146704&highlight=#post146704
http://www.diyaudio.com/forums/showthread.php?s=&postid=137191&highlight=#post137191
Here's a link to my all tweaked version of the Patek amp, and I can't presently see a way to improve it any further, but the way it's built is based on 4 years of tweaking experiments😉
http://www.diyaudio.com/forums/showthread.php?s=&threadid=76609&highlight=
The LM3875 Premium kit has not been changed in the last 3-4 years and it still offers the best choices in chip amp configuration, resistor values and types. The only thing worth experimenting with are capacitors, and I expressed my personal choices already. IMO, Panasonics FCs are the closest thing to BG caps, if you don't want to pay for the caps same money as for the kit itself.
Okay Dumb question coming...
I'm using your lm4780s and Marchand's electronic x-over. You said to use a 10k log before amp(I believe this size), while Marchand says to use a 10k linear after x-over. Could I use the PEC dual linear or should I use a log? And what size would be good? Thanks for your help!🙂
Bridged 4780 Subwoofer Amp
I need your advice.
I am using 1000uF BG STD on the amplifier board.
Would your same recommendations apply (as far as any additonal capacitance) to this application? Should I stick with 10 uF on the rectifier board or could there be some advantage to using a larger cap in this application?
Please advise what you would recommend.
I guess these boards were not made with the RIKENS in mind!
THANKS,
Plitron
Hii
sometimes i look you have cheaper product 😀
so why not i call you :devilr:
Peter do you have Plitron torodial, i need
- 1 X 400W, 50/60 Hz, +/- 60 V output or 😎
- 2 X 200W, 50/60 Hz, +/- 60 V output 😎
and please give me big discount for it 😱 😱 😱
oh yes please answer my last letter in your email,
realy realy your advice man
thank u, goodbye & best regards
jeffry_w
Newbie here...
Interested in building a 5 channel amp for theatre use. Any recommendations on Peters' kits?
Also, what type of transformer should be used? Should I use 1 or 5?
Looking for high power and great fidelity.
Also interested in DAC if this is still available.
Thank you!
