AudioSector-chip amp kits, dacs, chassis
DAC Trouble Shooting
Finally got around to finishing the DAC...it's been a very busy winter. Unfortunately, I am having some problems. First, I have 7.35V after R1 but only only 4.25V after R3. Second, is no sound at all. Any suggestions? :xeye: Amps have been working flawlessly, so all is not bad. 🙂
Re: DAC Trouble Shooting
If your CDP has output caps, it should not output DC. However, if you measure DC directly after caps, without shunt resistor, there may be a residual voltage present, which should dissapear after connecting to the next stage. Connect the CDP to the amp, with amp disconnected from the speakers, and measure DC offsets then: on amp's input and on amp's output.
If my calculations are correct, using 50k pot in parallel with 22k input shunt resistor and 2uF coupling cap will produce 5Hz cut off freq in worst case (it will also depend on pot setting).
What is the voltage on transformer secondaries?
karma said:
looks like audiooasis owns the webpage now. hmm time to remove that link. im sure thay make good money without my help
Audiooasis was always handling AudioZone sales. Personally I'm not impressed by new website either, it does not look professional. Well, they used different services than I did 😉
