Audiopipe apmi 1800.1, audio problem .
I have an audiopipe apmi 1800.1d that Powers up fine draws around 2.2amps of current at idle. All seems fine until I start to adjust the gain pot, the signal beacomes very strange. Sometimes it will even jump into protection. The signal despite 0 gain seems high to me. The gain pots have all been changed. As well as the power supply and output transistors.
I'll check perry. It's so strange that I didn't know how to explain to even ask for help. Originally I believe that the capacitors grounded out to the casing and brought the amp down. The leads were long and there was a large burn mark on the casing.
