Audiopipe AP 3000 1D
After replacing the divers with original part numbers and the 2 optocouplers on 1 board this is the drive signals I get in the high and low side outputs
Do these drive signals appear good or do I have a problem somewhere still ?
Scope settings are 5us 5volts/div
Here is a picture of the audio driverboard .
Do you know what ic controls the drive signal for the outputs ?
There is something defective on the driverboard which is causing 1 board to have no drive signal to the outputs .
I swapped audio driverboard a and the amp has drive signal on the outputs but this audioboard makes the amp have no drive signal
Voltage on the header of both boards
Non working board
Pin 1:-4.61
Pin 2:0.00
Pin 3:0.00
Pin 4:-12.97
Pin 5:12.97
Pin 6:0.11
Pin 7:5.00
Pin 8:0.00
Pin 9:5.00
Pin 10:0.21
Pin 11:4.66
Working board
Pin 1:0.00
Pin 2:0.00
Pin 3:0.00
Pin 4:-13.10
Pin 5:12.86
Pin 6:0.11
Pin 7:0.11
Pin 8:0.00
Pin 9:4.99
Pin 10:0.21
Pin 11:0.19
I’m working on this amp again replacing the lm219.
I noticed that neither board has drive signal on the outputs again .
I ordered new optocouplers .
1 set of optocouplers says
Lite-on high speed optocoupler 10MBd
The other set says
10Mbd open collector high speed optocoupler.
Are these the same pretty much or wondering what one I should use in this amp
