Audio Research LS2B tweak
wandelblu said:
Do you know something about this tweak?
Replacing a capacitor is clearly audible but can also be seriously exaggerated. Assuming the original caps are not total junk you may consider playing with various bypass arrangements instead.
It's a pretty nutty circuit if you ask me. Are all the components in the nfb path just trying to avoid an extra cap? Or is there more to it than i see? I'd be tempted to remove the opamp and surrounding components and replace them with a cap+resistor. Unless R43 has a very small value and requires an electrolytic.
