I''ve been looking for some tweaks about Audio Research LS2B and I've just read on audioreview that changing some caps,
It improve very much.
http://www.audioreview.com/cat/amplification/preamplifiers/audio-research/PRD_124807_1591crx.aspx
Do you know something about this tweak?
Doesn't anyone have the components layout of this preamp?
I'm looking for it.
Enzo.
I'm looking for it.
Enzo.
Replacing a capacitor is clearly audible but can also be seriously exaggerated. Assuming the original caps are not total junk you may consider playing with various bypass arrangements instead.
It's a pretty nutty circuit if you ask me. Are all the components in the nfb path just trying to avoid an extra cap? Or is there more to it than i see? I'd be tempted to remove the opamp and surrounding components and replace them with a cap+resistor. Unless R43 has a very small value and requires an electrolytic.
