Audio Research CD2 tray opening issues
[Solved] Audio Research CD2 tray opening issues
I have a Audio Research CD2 player which has a tray opening issue.
Probably just needs some cleaning but I am unsure how, and hoping people could give some pointers.
The issue is that when I press the eject button it might open half way, pause for a second and close again.
Sometimes it will open all the way and close immediately again.
This can happen several times and then it will open and stay open for me to lay in the CD.
Closing is usually OK but can experience funkiness too sometimes.
CD's, when inserted, play just fine. So I am assuming there is some detection thing that needs cleaning, but I don't know where it might be located.
Of course I tried looking it up, but all you get then is using a CD cleaner.
And since the laser doesn't seem to be dirty I doubt (but could be wrong) that is the issue.
Anyway, hoping to be able to use the player again since it's a very nice transport using AES/EBU. Never used the analogue outputs since, till the end of the month, I own a Devialet 400 setup. Switching to a Luxman L-590AX MKII then so would need a new DAC too.
Thanks in advance.
I would replace the loading belt. I think it is a Sony mechanism so nothing special.
Here is a rough drawing of the assembly from the service manual. The belt is under the tray.
Thought I had replied to this with an update, guess not.
I did replace the belt back in November of 2020, but nothing changed.
The tray will still get out partially and close, or completely out and close in one go.
It still feels to me like a sensor, of sorts, if that is possible,
When I had it apart to replace the belt I also checked the gears, and they feel fine to me when manually pushing the tray out.
I hope anyone else has an idea what to do.
I don't mind replacing something, I'm just not sure what.
Of course, I could look for an transport replacement (it's a Philips CDM12.1 iirc).
Found the switch. No idea why it didn't hit me before since it's fairly loud.
Anyway, when taking it apart from the transport and using my multi-meter to beep its connections, I notice the contacts make a bad connection.
Could barely get a beep out of it.
So I definitely need to find a replacement for that. Anyone know the exact name for it? 🙂
Also, when pulling the transport apart I noticed the center thingy that goes into the CD hole and pushes it up against a ceiling ring (really now idea what they are called) has cracked on top. It's like the chrome/plastic part.
So that needs a replacement too.
Feels like I will need to look for a entire replacement for that part?
Also made a picture of the exact CDM model. CDM 12.4/05
Problem solved. Dad to the rescue 🙂
Turns out the problem were the contacts having baked dust on them, or corrosion.
Something like that.
Fix was to use some 12000 grid sandpaper and rough it up a tiny bit so it properly makes contact again.
Tray opens and closes fine again 🙂
Thanks for all the suggestions here too.
