Need Help:5AR4 SPICE model problem
I tried to use the 5AR4 SPICE model in Multisim14, but could not make it work
1, I try to use the 5AR4 of the Multisim14, the multisim reports error when run the simulation
2, then I use the 5AR4 model of the DIYAUDIO, the simulation can work, but the output is only 2.5V. the SEC of the power transformer is 0-5(for the filament of 5AR4) and 230-0-230(for the HT)
what's wrong with it?
Try LTSpice, it’s easy to use and free
+1
Are you select the output (click on it) after running Transient?but no output
What about View-> SPICE Error log?
Wouldnt your voltage be 325v?
I thought this was peak voltage input, 230x1.414=325m RMS would be 230?
Thanks,It works now
I should find some book about LT-SPICE to learn, it is not as easy to use as Multisim, but more powerful
Skype or "Gotomeeting" with someone that can show you, I learned more in 30 minutes than 2 days of studying.
Or Youtube some tutorials
- Tubes / Valves
- Audio Note M10 Clone
