Maxx134,
I would love to hear your experience with Audio Note Kaisei Non Polar
did you try In other application than cathode bypass
what value and voltage
do you recommend using bypass to flatter heavier bass and warmish character
Put Kaisei caps on a Krell KSA100 MK2
They were very smooth sounding. I like them more than Mundorf but ultimately I felt they robbed the dynamics a but by being so smooth.
I went over to some Vishay caps, blue in colour, can remember the model number but they were far better.
I've been mucking around with passive components for a long time. Putting aside the sound etc. all components have a certain sonic signature. Taking caps for instance, what sounds good on 1 location does not equals good sound when used everywhere. For bipolar caps, I've always found that by connecting the positive leg of the cap to the ground plane on a positive supply line to sound better.
Cheers
Cheers
do you bypass bipolar caps
which type are you using
Cheers
No I use bipolar as bypass caps. What I would recommend is that you make the first stage of the PS as clean as possible. Do not think that local decoupling will cure the ills coming from mains, rectifiers, transformers, ps caps etc.
How does a bipolar cap have a positive leg?
It is essential to specify if these were bipolar. Also value and circuit position.
Oh, sorry,It is essential to specify if these were bipolar. Also value and circuit position.
Not Bipolar,
Used in the Krells power supply
Aaaaah Analog_Sa that is what everybody assumes. Go use a Dvm to measure the cap, you'll see one reading will be in positive & the other in negative. To be accurate if there's only millivolts in the cap, then use either a 1.5v battery or whatever low voltage stuff you got on hand, just charge up the cap & measure. This too applies to film caps
Cheers
Cheers
Oh, sorry,
Not Bipolar,
It must have cost you a fortune to use so many Kaisei in the PS Bigman80.
Cheers
Sorry, Sumotan, do not get what you are saying 😱
If i charge a cap with a battery it will retain that same polarity, right?
Hi Analog_Sa,
Charging the cap is just to bring up some voltage for you to measure the cap. Caps will always retain some voltage in them but to measure what I spoke off it's more accurate to get the caps into volts rather then milli volts as that will give you the wrong reading.
The effect that one gets from connecting positive to ground is clearer overall sound & better prat more dynamic. Be it on PS or decoupling it is easily heard.
Cheers
Cheers
Btw the credit should go to Peter Daniels he was the one who discovered the BG NX that he loves to use sounded better when connected the other way round. Me only discovered that bi polar caps when measured via dvm still shows their polarities.
Cheers
Cheers
Just FYI:
When I noticed that one lead on Reliable Capacitor's RTE polystyrene caps was shorter than the other I wondered if it was significant -- if these caps were directional. I couldn't find any discussion or advice about this so I simply asked Reliable.
The new owners said that other than the fact that "The shorter lead is just where one side wraps around one end and along the body of the cylindrical cap before it is placed in the potting case" they weren't sure. In other words, as far as they knew it was just an artifact of manufacture.
That said, they also indicated that they were going to investigate the benefit of marking the caps "to designate the outer foil side" if evidence indicated that it was significant.
If Im not mistaken Auricaps does do with one end in Black wire & the other in Red.
In any case should not trust this. I've measured Muse BP & came across some that was wrongly indicated including the longer leads.
There are fools born every minute who invest in such nonsense, it keeps the money flowing based on myths and hype.
Well for what Audionote is asking for I'll surely will stay away. LOL. Having said that, I've played with Black Gates for sometime in low voltage applications. They aren't that transparent but what's so different about it is their to die for bass & the ability to make instruments etc sound more real. Myth or Hype well
to each his own I guess.
Was not the big Caps,It must have cost you a fortune to use so many Kaisei in the PS Bigman80.
I'm trying to find the pictures but they are elluding me.
Disregard my post for now as I cant remember exactly where they were in th circuit.
There were 4 of them, 2 on each channel.
Yes, but this only indicates the outer foil. I wish other manufacturers were also consistent with this.
Not arguing that most parts and in particular wire sound better in one direction, just not understanding the dc charge thingie.
Really interesting. I would also place the Kaisei above Mundorf in speed and dynamics but would never expect and industrial cap to beat them. If you recall the Vishay model i'll order some samples immediately 🙂
- Design & Build
- Parts
- Audio Note Kaisei capacitors
