Audio Gods AG 7000.1D
Did the amplitude of the low-side increase?
20k is correct if there are 5 of them on that side. 100k/5 = 20k.
Can you see what frequency they're oscillating at before they overheat (clamp them if necessary to prevent overheating)? Before, they were seeing a signal of about 100Hz (whatever you were driving into it). Are they now oscillating near 80kHz?
Touch your scope probe to the negative rail and make a note of precisely where it deflects the trace. Then probe the emitters of the drivers for the low side. Is the problem that the drive signal isn't going back fully to the rail or is it that it's not driving far enough from the rail?
Do the same on the high-side.
I'm not sure i follow Perry, the drive signal is present on all the pads, its just the amplitude that's the issue.
the high side has an higher amplitude than the low side.
voltage high side gate to source is 7.6v and low side is 3.8v
