-90 on the third isn't too bad for the integrated.
Anyone done multichannel on this guy yet? I haven't dug into the documentation to see if we can slave 6 channels on to the GPIO/I2S or if it has to be done via USB.
The Allo Piano 2.1 has two i2s-capable DAC chips driving four channels -2 left, 2 right. No idea how they are managing that, whether both DACs are receiving the same stream or whether all four channels are on separate serial streams.
Not sure where you are getting your numbers, but the 3rd order distortion for the integrated sound codec on the Tinker board was 0.0223% in my measurement, which translates to -73dB with respect to the fundamental. Also the total noise floor is only down 73dB below the fundamental level (0.0483%-0.0250%=0.0233%, or -72.65dB). These number are pretty crappy for a DAC. OK for casual headphone listening perhaps.
In the other plot, presented as a comparison, the 3rd order distortion of an inexpensive ES9023 USB dongle was -107dB (0.0004%) and the total noise was about -85dB below (0.0055%). Also, the maximum output level is higher by over 10dB, meaning it can drive amps with over 1V input sensitivity. All in all this is a good DAC for the price (which was way under $50 for a populated PCB).
Charlie -- I mistakenly didn't see that your primary harmonic wasn't at 0 dB.
Zoot -- thanks for the info! At least someone's out there doing it in some capacity. I'll have to take a closer look at what IO is available.
Ah, that makes sense now. The software uses the max input level of the ADC as 0dB. I wish I could scale the data so that the fundamental is always at 0dB to avoid exactly this type of confusion, but I can't seem to find out how to do it (it's REW v5).Charlie -- I mistakenly didn't see that your primary harmonic wasn't at 0 dB.
All good. 🙂 And usually I distrust the %age numbers as they can be easily monkeyed with depending on bin width.
In searching around, looks like there's only one stereo I2S arrangement. Not sure if some of the other pins can be thus reconfigured. Might make more sense/simpler to pipe it all through USB.
From what I gathered whilst mooting 2xPlainAMP etc a year or so ago....
I2S on the Pi is 2 channel output.
It is possible to I2C address DACs or AMPs via bus address (0/1 that I know of) to program/load different DSP into each DAC/DSP/AMP.
PlainAMP had a jumper to select bus address if running two in parallel. I guess Piano 2.1 has it controlled on the board.
So each DAC gets the whole stereo signal sent to it. The DSP decides what to do with it after that.
J.
I2S is not, as you say, "2 channel". I2S is a hardware communication bus. What data you send over that hardware is determined by the software interacting with the I2S bus on either "end". You can send and receive lots of audio channels if you want - just check out the "Octo Pi soundcard" from Audio Injector for an example.
The point being made is that we have this lovely microcontroller already, and you have to figure out a means of breaking up a 8-channels I2S stream into 4 stereo I2S streams to interface with at least any of TI's, Cirrus's, or AKM's DACs (I just checked DS's). It'd be nice to not have to use another layer of glue to get the job done.
Ah, not so much of a hardware or microcode limitation then.... More of an OS or driver thing if there's a limit anywhere?
Well the serial bus will only handle so much data rate, but audio bandwidth is pretty small. The greater limitation is that the dac will expect 2 channel i2s input, so you eventually have to break apart the data stream.
TinkerBoard and HATs?
Anyone know of a digital out HAT board or DAC board that works with Tinkerboard and volumio?
Where are measurements of at least HD distortion and noise floor?
Without these, your link is just a bunch hand waving. It doesn't matter if the audio is 32-bit if the quality of the audio is bad...
Hand waving? What do you want from me? The guy asked if there were any dac for the tinker board. I saw this article prior to the question being asked. I provided a link. There aren't that many dacs for this single board computer.
The tinker and the dac are newer products. Contact the manufacturer is you've want data.
My point was that the link you gave led to a page that was long on praise but short on actual data, measurements, etc. How should I trust it?
The Tinker board can use virtually any linux compatible class-compliant USB DAC. There are many in this category. No need for special HATs and drivers that might go obsolete when the OS updates...
Its not my job to provide anything.
Stop flaming people for trying to help.
Do your own resesrch.
Hey man, chill out. I didn't mean it as an attack on YOU but on the web page you linked to. Maybe my reaction was a little harsh, but I am so sick of flashy products like this for audio that have very little if any information, or give specs by quoting the manufacturer data sheet instead of taking actual measurements of their particular implementation of the IC. (HINT: often times performance is worse). That's what popped into my head when I opened your link.
So I did my "research". Here is the link to the product at the seller:
DACBerry ONE for Raspberry Pi A+/B+/2B/3B – OSA Electronics
Specs? Nothing, except "Up to 384kHz / 32bit resolution". So what? It might be good. It might be crap. Who knows - there is no data provided. But it looks shiny and cool and cost only 50 Euros. So go for it if you like.
DacBerry One
I followed up on the manufacturer's forum and they said the unit will work with Tinker Board. Volumio has a download specifically for the Tinker Board. I was gong to get a Pi, but I may try the Tinker since it will run faster and has better ethernet.
Just got a Tinker Board on eBay for $53 with shipping. So in a few days will load Volumio on it and via its USB outlet connect to my Emotiva DAC and tell you what I think. If that does not produce quality sound, I will look for a compatible SPDIF out HAT.
- PC Based
- Asus Tinker
