Artemis - the NASA mission
In this context we mustn't forget that in comparison with the KSC in Florida the UK is further away from the equator, which means more powerful rockets would be required for the same task if launched off the ground.
On the other hand, a proposed spaceport to be located on the A'Mhoine Peninsula in Sutherland, in the far north of Scotland, is in an ideal location to utilise small, vertical launch rockets to take satellites into the polar orbits required for Earth observation.
https://space.blog.gov.uk/2022/03/16/on-the-ground-with-space-hub-sutherland-and-orbex/
Due to the Earth's rotation, a satellite in polar orbit will eventually pass over all of the Earth's surface so can gather information about the entire Earth.
That link took me to the Ideal Rocket Equation variously attributed to the Russian Constantin Tsiolkovsky, the American Robert Goddard and others.
Delta-V or ΔV is derived through conservation of momentum.
For every unit of fuel ejected from the rocket, the rocket and the remaining fuel gains momentum.
If we wanted the rocket to gain even more momentum, we could simply load on more fuel so that we have more to eject.
However, there's a problem as each unit of fuel has to accelerate not only the mass of the rocket, but also the mass of the remaining fuel!
This means that the more fuel that is carried, the less effective each unit is at providing the rocket with momentum – it’s a problem of diminishing returns.
The greater the delta-V required, the greater the mass ratio between wet mass (full of fuel) and dry mass (empty tanks) that is required, and the more difficult the rocket will be to engineer.
Using integral calculus to model this problem of the rocket accelerating as its mass diminishes gives us the Ideal Rocket Equation.
Now, I understand conservation of momentum, but there's no argument that this is rocket science! 🚀
I've extracted the above information from the following source which also provides numerical examples relating to real rockets:
https://www.marssociety.ca/2021/01/07/rocket-physics-the-rocket-equation/
Getting out of Earth's Gravity Well needs much fuel and expensive Boosts.
But after that everything is free. Hydrogen, Oxygen, Sunlight for Electric Panels. Building materials. And Powerful Fusion Rockets can't be too far down the line.This is what the Rocket Scientists have realised.
We just ride Lagrange points to get around, albeit with minor course corrections. Maybe Electric Rockets. Regard Chaos as a feature of the Universe rather than a bug. Employ the Butterfly Effect in that small changes make a big difference.
https://en.wikipedia.org/wiki/39P/Oterma
https://en.wikipedia.org/wiki/Genesis_(spacecraft)
The Interplanetary Superhighway aka ITN:
https://en.wikipedia.org/wiki/Interplanetary_Transport_Network
Quantum Mechanics and General Relativity have always been the Glamour Performers of Physics, but many secrets lurk in stodgy old Classical Mechanics.
https://www.amazon.co.uk/Calculating-Cosmos-Mathematics-Unveils-Universe/dp/1781254311
Hope I condensed a complex subject well there.
Reactions: TNT and Galu
Pfft. 😳
