Joined 2003
Joined 2003
Just for a bit of additional information, I can provide some comparison with SoundEasy and REW included as well. I took a little bookshelf speaker, and measured in ARTA with sine sweep, 4 measurements overlaid, hanning window at 4.3ms.
ARTA Sine Sweep, not very good consistency / repeatability at low frequency:
Same sine sweep measurement in SoundEasy, same hanning window at 4.3ms provides very good consistency / repeatability:
Same result in REW, sine sweep presents no issue with consistency / repeatability, in fact the measurements are perfectly overlaid that you can't see the other three, you'll have to take my word that 4 traces are shown.
Based on this, I don't see the problem as anything inherent to a dual channel sine sweep measurement, or the Motu M4 hardware.
Joined 2003
Joined 2003
Joined 2003
Excuse my ignorance, how do you chose Swept Sine? I can't find it......
I can comment on the REW results in case that helps. REW does not perform what I would consider to be a dual-channel FFT measurement, the differences are more than semantic. It is carrying out two single-channel log sweep deconvolutions on the input channels and uses the windowed IRs resulting from those measurements to correct the primary channel. That means harmonic distortions have largely been excluded from both results before the correction happens, which may be a factor.Hi Dcibel,
thank you for your measurements.
I have 3 interfaces. Two works OK (RME and Roland Rubix) while third (Komplete Audio 2) behave just like your Motu M2.
I will surely spend some time to find what happens.
Ivo
Yesterday and today i did the same tests, to see how much it varies.
In short the sine sweep has what appears as a DC offset effect, rising with ~6dB/oct towards lower frequencies, also with occasional a serious outlier ?!
Periodic Pink noise is the best option. Periodic white noise is worse. Lower sampling frequencies and/or lower FFT periods does not significantly change this behaviour.
Sweep: (IMP-Setting-10 ; IMP-Setting-10-IMP-View ; IMP-Setting-10-SeveralTimes-FR),
Periodic Pink Noise:
(IMP-Setting-11 ; IMP-Setting-11-IMP-View ; IMP-Setting-11-SeveralTimes-FR) although at very low frequencies (<20Hz) again a rising curve of ~ 6 dB/oct:
At lower sample frequencies and FTT length, in essence the same:
(several measurements litterally the same output!)
Periodic White noise is worse compared to periodic pink noise:
Joined 2003
Thanks for your verification. I agree that with sine sweep there is occasional outlier, perhaps 1 in 10 measurements appears very good, but repeatability for exact same measurement conditions is not good, which is a problem in itself in addition to the rising noise floor at low frequency. In any case, it appears that Ivo has been able to reproduce this with some of his own measurement equipment and is looking into it. In the meantime, periodic noise is the solution.Yesterday and today i did the same tests, to see how much it varies.
For your PN measurement, below 20Hz you are likely seeing rolloff of equipment frequency response, so this behaviour is expected. single channel loopback will confirm.
I'm sorry, I sort of lost track of this request... I can't tell from the recent activity if you still need me to do this. ?If you wouldn't mind, simply run a TRS patch cord from input to output, set the reference level to -10dBFS, and record with nothing connected to the measurement channel, compare PN to Sine Sweep.
Joined 2003
February, 2, 2023; ARTA software version 1.9.6 is published.
Note: To download ArtaSetup196.exe you will have to choose left download menu, then twice choose See more and Keep options.
Microsoft just need few days to approve download.
Ivo
- Measurement with swept-sine signal in dual channel mode is improved by better control of sub-audio noise.
- Several small bugs are corrected
- This version no longer works in Windows XP
Ivo
Joined 2003
Thank you Ivo!
I have checked the new version, and while there is still some small error in repeatability of sine sweep measurements, the overall noise floor is incredibly improved. In the image below, same noise floor measurement as previous, with no input and -10dBFS reference channel. Solid green is periodic noise, the overlays are sine sweeps, 1 of 4 measurements is a bit out of place but overall the result is a huge improvement!
Tested ARTA 1.9.6:
My conclusion:
Significant improvement over Arta 1.9.4 : a level to noise of 90-100dB, less strong outliers if any. The typical "wing" is below 20 Hz of even below 10Hz and less pronounced.
Case PPink-256k:
Result:
Note: Home button (sampling zero is 300):
If cusror at 270 instead of 300, it makes some difference, still prefer the 300 samples home:
Case Sweep 192kHz:
Quite good as well, but occasionally a not so strong outlier, also the Home (300) vs cursor at 270 makes a not so significat difference.
Case Sweep-96kHz:
Basically same picture with 96kHz-256k:
Note that the position of cursor has an effect, both in level(ampliture) and in pattern of the open input noise(in overlay the bottom two entries (red, level, noise) are with cursor at 300 samples.
My conclusion:
Case PPink-256k:
Result:
Case Sweep 192kHz:
Case Sweep-96kHz:
