Arcam Delta 70.2 digital filter
Just found your site-looks great,
I'm a bit of a digital virgin, but I've had great success moding my TDA1451A equipped player. It's got a SRPP ECC88 output stage with battery negative grid bias, a first order passive filter and some PSU upgrades and sounds miles better than standard.
I'm now looking to the next upgrade and wondered if anyone could advise me on the feasibility of bypassing the digital filter in the SAA7220.
Obviously I'd need to do something about the clock but what else?
Any wise thoughts would be appreciated.
Simon:
Transport screws
I was lucky enough to get the Delta 70.2 and was wondering if it is possible to secure the mechanism with transport screws prior to having it sent to me.
Hopefully, one you Delta owners could have a quick look at the underside of you machine and let me know.
Re: Transport screws
Hi Fin
Could you please advise how to secure the machine before transport. I understand there are 2-3 screws underneath which need to be ? 'tied together', but I am not sure. Many thanks
Fib
Re: Re: Transport screws
FibCouple said:
Hi Fin
Fib
When the CD player was supplied new - it would have had two transit screws fitted underneath. They are screwed through two threaded holes in the bottom plate and make contact with the top plate of the CDM. They prevent the CDM from moving around too much on its suspension during transit.
Before use, these two screws are removed and should be stored in the storeage holes on the back plate. When you plan to transport the machine again, you should then re-insert these screws into the threaded holes in the base plate.
It is always better to use the transit screws if available - however, if they are misplaced, it should be okay to transport the machine without them if reasonable care is taken. I have received about 20 CD players with CDM2 and CDM4 in the post - without transit screws fitted - and all of them survived the journey.
Below is a picture of the rear of a Delta 70.2 with the transit screws in the storeage holes just above the RCA outputs on the right hand side. They look just like two knurled knobs. If they are there......unscrew them and find the appropriate holes for them underneath. They should be directly below the CDM.
Hi Fib
Great news!
Let us know when you get it and what you think of it.
As Jean-Paul said in the other thread, it is not a machine to rush into with a load of ad-hoc mods. It has been designed pretty well to start with so it needs careful consideration. Also, be careful with the case. It scratches easily and the screw holes strip easily too.
The one mod that is an absolute must even if you don't install a new clock - is to disable the SPDIF signal from going through the 74HC74 shared with reclocking of the bitclock. Apparently this alone can have a huge improvement and is the only real flaw in the design.
