I'm never going to buy anything again from the internet from someone who says he tested everything without hearing and seeing it myself.😡
Anyway, the bright side is I got help from you guys and I learned how to look for mistakes!
That will happen again and again...😛I'm never going to buy anything again from the internet from someone who says he tested everything without hearing and seeing it myself.😡
It sometimes makes one spanking mad, but, usually ends up as a learning experience...and...most important(?), you learn that the world is actually full of helpful peopleAnyway, the bright side is I got help from you guys and I learned how to look for mistakes!
Arne K
The story continues hopefully without further problems 🙂
A new cabinet (is that the correct term?) arrived today from Italy!
I accidently put on the top panel with the ventilation holes on the wrong side...
Nice enclosure Leeuwarden! Modushop I presume? Which model is that?
Does the assembly instruction still come in Italian only? 😀
Thanks, this is a "slim line 2U" with 10mm front and 350 mm deep.
Instructions are in Italian and English. I wouldn's call them "intstructions" though... It's a piece of paper with an un-understandable drawing on it 🙂
damn. i soon got the same setup🙂 i got Ucd 400hg. and soon a aleph 1.7
(in a 2U 400mm black pesante chassis) with
control, attenuator (relVol3), input selector and display from dantimax.
but im putting my relVol3 on the inputside of the amp. with 1Kohm resistors.
Well, it was up and then it went down again. I'm using a dual mono powersupply and one half is suddenly giving me a staggering 85V. 🙁
- APOX volume-input for Aleph P1.7 question
