I have asked ALW and algar if it is ok to suggest a group buy of jung reg pcb's on the forum and they have both approved, as usual a diy non profit affair. I tried to attach the eagle pcb layout but the file is too large. So is anyone interested in pursuing this further? I'm sure we all have uses for regulators when tweaking and if there's enough of us perhaps the cost will be worthwhile....
There will be work involved with gerber files etc so we will need someone to volunteer for this. I can help out with shipping etc in the UK.
Raja
Raja
----------------------------------------------------------------Raj1 said:Hi,
Raja
Interested in 5 sets of +ve and -ve. Will help in Uk but cannot host large files.
Fred
Please note that sometime ago Mr. Jung has asked not to use his name for these regulators as they are no longer identical to his designs. Just to avoid future discussions.
Jan Didden
Jan Didden
Hi fmak,
Well I'm glad someone else is interested also, but we'll need more than a few boards to bring the price down sufficiently. Anyone able to do a gerber file for the regulators from the eagle layout? And perhaps suggest a pcb maker who can do this at a good price. I want around 10 boards or so............
raja
raja
The price to beat to make it interesting is 7$/board.
That's the price AOS wants for a pcb (negative or positive).
http://members.shaw.ca/aoselco/aos/jungsrpcb.html
I have direct access to a local electronics maker. He burns all his own boards, and also does multilayer? he does double side as well.. Small runs. Any of the crew here want to do a run of some really tricky DAC multi layer boards, we can make a go of it at pure manufacturing level expense. I will only entertain it if the files are properly set up, and exorsized, etc.
Is this really a matter of price? 7 USD is very fair I think for this small pcb. Anyway I'll wish you good luck with this.
BTW: Have you seen BrainGT and my pcb's?
http://www.diyaudio.com/forums/showthread.php?postid=246231#post246231
http://www.diyaudio.com/forums/showthread.php?postid=268429#post268429
well, i don't know....perhaps i make'm myself, it's just that i don't think i can have them produced at that price....but let's see what the final cost will be, then i'll decide....🙂
still at a sticking point with gerber and the drill files. I've never used either of the programs or designed boards. Anyone upto the task?
7$ a pcb is fine, I think. I'd go for around 10 at this price........
Raja
Raja
if one of you can send me the cad files i will try to extract the drill and plot files for you.
send to stones.server(AT)virgin.net
Uses ?
Raja,
I'm a newby watching with interest. I've visited several sites to gain an understanding of the uses for this regulator. Is the following correct?
Current capacity ~ 1.5A
Voltage Max ~ +/- 15V (Can this go higher?)
Applications would include those which would benefit from a low noise power source such as pre-amps.
Thanks for your efforts.
Ed LaFontaine
Raja,
Ed LaFontaine
00940 said:The price to beat to make it interesting is 7$/board.
I just ordered a few boards from Andrija Ifkovic.
I'll report back when they get in.
Re: Uses ?
Check this link for info
http://www.alw.audio.dsl.pipex.com/Manuals/ALWSR_rev2.9_Iss004.pdf
Raja
bg40403 said:Raja,
Ed LaFontaine
Raja
Find below the manufacturing files for the positive version (can someone please see if they are ok) I have split them into top, bottom and ident as separate files they can be generated as one complete file if required.
I could also save them as a bitmaps if someone wants to make the pcb’s from plots (a bit of rescaling may be required).
Let me know if the above is of use and if the other pcb –v version is required and in what formats (file per layer, all in one file or bitmaps?).
If I can get my head around the http://www.alw.audio.dsl.pipex.com/...v2.9_Iss004.pdf
Information I will probably redo the layout in protel as one single + and – pcb as it would be less expensive and I could make it so that it can be cut in two if required.
Hi Mark,
I've never sent files off to a manufacturer before for pcb production, so if you know what's best I'll go with it. Having the negative and positive versions on one cuttable board maybe of use, but my gut feeling is that there's more of a demand for positive regulators than their negative counterparts, ofcourse I may be wrong and I do need some negative boards too.
Whilst we're on the subject, can someone suggest a good reasonably price pcb manufacturer in the UK who can undertake this?
Raja
Raja
Hi Raj1,
I would suggest that some one send the previously attached files and request a preview plot from a pcb manufacturer, most did seem to prefer separate top, bottom, silk and so forth (as attached in last post) due to the fact that they then don’t have to mess about working out what layer is what.
If someone has time do searches for something like gc preview (or pcb file viewer) if my memory serves me correctly it is (or was) a free viewer only version of a program called gc place generally used to gain coordinate data (for automatic assembly) and to change the paste mask aperture sizes for the correct stencil manufacture.
Please report what you find.
I have been reading your posts with interest! However the link
does not correctly download the specifications. It seems it is encrypted. Would someone please direct me to part lists and specification for this pcb, since I too am very interested. Thank you.
Best Regards
Amir
Best Regards
Amir
- Group Buys
- anyone interested in a jung regulator pcb group buy?
