anyone have any opinions on these?
I know they're car drivers but I meant for home .
Well this is what I wondered . if they're was enough info to make an informed decision or not . it's quite a lot of money to risk if they're not very good . I'll message the company see if i can get those graphs .seems like even less specs of drivers are given out in the car world seems like people buy on name and reputation .
IT is kinda' hard to say as the "specifications" listed are kinda vague. The likes of a graphing of sound pressure vs. frequency would be very helpful to evaluate its performance. The dome midrange has "come back" in vogue...its advantages being supplanted with ribbon tweeters and the odd collection of wideband tweeters as of late. The big dome midrange is making a comeback in popularity.
We really need more data to nail down this "built in crossover"...why it was incorporated....we can guess that it was incorporated to save it from primitive implementation with no low-end protection (filter), the driver popping out from low frequencies passing thru. I'll look it up to see if we can find more data.
---------------------------------------------------------------------------------------------------------------------------------------------------------------------Rick...
FYI/FWIW/YMMV.... I used Infinity mobile audio drivers for small upscale HIFI/HT and based on what little info I found these appear to be at least as good and with neo motors are in theory a bit better; for sure I'd at least audition them and price wise quite a bit cheaper after factoring in 20+ years of inflation!
thankyou Rick.
and yeah it's a bit frustrating the lack of fr resp etc ,lately I've been looking at dynaudio car drivers and the one place that sells them provides almost no data to go on .
unless I'm being blind and have missed it somehow ? .
dynaudio told me they dont provide ts parameters.
Reading between the lines the mw182 seems to be the same or very similar to the 24W-100 xl, which I think is quite a good driver works in a smallish box sealed or ported etc
...lately I've been looking at dynaudio car drivers and the one place that sells them provides almost no data to go on .
Official website provides pdf brochure on automotive drive units with spl and impedance graphs.
Should there not be T/S parameters, as is the case for 3" midrange dome, for the sake of it,
it can be calculated using formulae on traced impedance data.
My opinion is Dynaudio mid MD142 is heavily overpriced. Instead, get a 2" Visaton variant.
This drive unit is absolutely over the top in resolving recorded sounds.
yep agree about the md142 i think id rather spend my money on that tangband 3"middome but I'll have a look at the visaton one too thanks for the heads up on that they seem to have quite a few interesting reasonably priced drivers .and thanks you're right I had already downloaded that pdf and had forgotten about it !!
If you want cheap, used- hit the Auto Wreckers (Pick A Part, Pick N Pull, self serve) some will remove the parts for you (?$).
You'd be taking a chance with used drivers though, some with odd mounting, some abused, etc..
Bring a small 1.5 volt battery , wire, to test & multimeter. Bring tools, a drill & drill bit - some are pop rivetted.
Some examples:
Dynaudio
Volvo, years? C70, S80, XC70, XC90
Volkswagon CC 2009-2016, Passat 2006-2010, Passat Wagon 2007-2010, Golf years? Tiguan years? Jetta years?
https://web.archive.org/web/20071231105719/http://www.dynaudio.com/eng/auto/c70.php
https://dynaudiodata.blob.core.windows.net/media/2510/dyn_automotive_brochure_int_dp.pdf
Google, Ebay, etc Dynaudio Volvo, Volkswagon
BMW
LPT/Nokia speakers 3,5,7 series, etc
http://www.hifi-forum.de/bild/itt-specs1_492627.html
Jeep Wrangler 2015-
Alpine 3 1/2" Fullrange
https://www.diyaudio.com/community/threads/2-3-fullrange.310287/page-2#post-5179897
https://www.moparpartsgiant.com/parts/mopar-speaker~68223392aa.html
I would look for these (Check the ohms- some car speakers are 2 ohms):
(pictures 1 &2) Volvo C30 C70 Dynaudio Center Channel Speaker Mid + Tweeter OEM 30772942
Volvo OEM Passenger Dynaudio Premium Front Door Speaker XC90 30752353
Volvo OEM Passenger Dynaudio Premium Rear Door Speaker XC90
Easy - Install in an open baffle + powered sub. Cheap.
Harder- Pass OB SLOB
https://www.diyaudio.com/community/threads/pass-slob-build-discussion.300952/
Hardest-Lampizator Project 7 (woofers n/a) or similar.
https://web.archive.org/web/2021102...pizator.eu/SPEAKERS/PROJECTS/P7/PROJECT7.HTML
Dome Mid
Volvo OEM Dynaudio Mid-Range Dome Speaker 3533792 for C70 1998-2004
06-13 Volvo C70 Dynaudio High Performance Mid Range Speaker 30679365
My local Pick N Pull has speakers for $7.99 each CDN
https://www.picknpull.com/part-pricing/164?navitem=s&searchcriteria=s
Reactions: GM and jotom750
