Anyone build a bigger la scala with/for the 15pr400
Alright — let’s calculate the new horn mouth area, throat area, and cutoff frequency when scaling up the La Scala by 20%.
📐 1. Assumptions about the original La Scala​
  • Horn path length ≈ 2.6 m (102″)
  • Mouth area ≈ 0.4 m² (4.3 ft² ≈ 24″×24″)
  • Throat area ≈ 0.02 m² (about 3 in²)
  • Cutoff frequency ≈ 104 Hz (theoretical)
    (This is derived from the mouth area.)
We scale everything by a factor of:
Code:
s = 1.20
📐 2. New horn path length​
Already calculated:
Code:
2.6 \, m \times 1.20 = 3.12 \, m
📐 3. New mouth area​
Area scales with the square of the linear scale:
Code:
A_\text{new} = A_\text{original} \times s^2
So:
Code:
0.4 \, m² \times (1.20)^2 ≈ 0.4 \times 1.44 ≈ 0.576 m²
0.576 m² ≈ 6.2 ft²
That’s about 30″ × 30″.
📐 4. New throat area​
Similarly:
Code:
0.02 \, m² \times (1.20)^2 ≈ 0.0288 m²
0.0288 m² ≈ 44.7 cm² ≈ 6.9 in²
📐 5. New cutoff frequency​
Horn cutoff frequency depends inversely on the mouth size.
The approximate formula is:
Code:
f_c ≈ \frac{c}{2\pi} \sqrt{\frac{\pi}{A_\text{mouth}}}
where (speed of sound).
If you scale the mouth area by , the cutoff scales as:
Code:
f_{c,\text{new}} = \frac{f_c}{s}
So:
Code:
104 Hz / 1.20 ≈ 87 Hz
📋 Final Results:​
ParameterOriginalScaled ×1.2
Horn path length2.6 m (102″)3.12 m (122.4″)
Mouth area0.4 m²0.576 m² (6.2 ft²)
Throat area0.02 m²0.0288 m²
Cutoff frequency~104 Hz~87 Hz
✅ After scaling up the La Scala by 20%, you get:
  • ~22″ longer path
  • ~44% larger mouth and throat areas
  • ~17 Hz lower cutoff frequency (~87 Hz instead of ~104 Hz)
If you’d like, I can also help you draft a table of new dimensions (height, width, depth) or even draw a scaled plan. Let me know!
ChatGPT...
How in all the world do you come to a horn path length of 2.6m in a La Scala ?
It is much less than half of that actually.
If this were correct the following would happen:
2.6m combined with your throat and mouth area would give a horn-constant based cutoff frequency of 31 Hz for the original and 27 Hz for the enlarged one. Since the throat area would be much too small for that the frequency response would be very irrgular.
But since your path lengts are way off this will not happen that way.
Charles
Reactions: Bas Horneman
I strongly recommend that you only use AI for topics that you know enough about so that you can check for yourself whether what the AI claims is true. AIs are otherwise all kinds of things, but they are not reliable sources of information.
I think it's basically already been done...31 Hz F3 (eighth space loading):
(anechoic response - full space)
Be careful of the dimensions at the back of the bin--near the 180 turn (point "C" in the AES paper). This seems to be the place where errors in DIY drawings were made in the past.
You can make this bass bin single-height (12" woofer) or double height (two 12" woofers)--like my bass bins. I recommend the flat "shelf-type" stiffeners instead of the original "struts" used on the first bass bins (like the ones I own). The shelf stiffeners locate the other pieces (like a jig) much better and significantly decrease assembly time.
Chris
