Any DJ’s in the house?
Yes, you missed that too, I guess. 🙂 Didn't work either.
Anyway, I'm having that little program (tactile12000) which does a pretty good job. If my neighbor likes it, things are sorted, if not he'll have to dig some deeper into his pockets.
/Hugo
Are you positive the multichannel support doesn't work?? The website consistently/repeatedly mentions multichannel support in FDL.
I've done a quick setup on my mac - not with the indigo, unfortunately. With FDL setup for multichannel support and PFL crossfader set to the "cue" deck it definitely sends PFL to the rear channels. Did you check what was happening in the Console app when you were setting things up?
I've messed around with audio apps long enough to know that correct setup isn't always the obvious way to do things 😉
Could you explain how the pfl didn't work "as planned" in FDL? It is quite possibly a config issue.
