another cosyne synergy speaker build
A more complicated option would be to remove the wood flange and make a wider aluminum flange that is first bolted to the driver and then bolted to the back of the horn.
That's what I've ended up doing.
It's also helped with trying different size cones and patterns, as it's more of a 'universal' mount.
Plus it's not to hard to match plate hole to driver, and then match the plate to cone. Easier to get good driver to cone alignment i think..
I can align the driver so that two of the screw holes are accessible - I would be able to fit socket cap screws in there between the mid drivers. would two screws be enough?
As long as the two holes are on opposite sides of the driver, and the mounting flange is well attached to the horn so that it won't warp, two holes should be OK.
Using studs in the driver and nuts may be easier to fit, though I recall some bloody knuckles resulting from my SynTripP HF driver attachment...
Art
Thanks for the replies! I'll start with the simpler two bolt with wood flange. and evaluate from there. I think switching to an aluminum plate would be a better long-term solution but I should be able to revisit that after getting things up and running first.
I have been test fitting drivers. the cone drivers are straight forward but the CD is giving me trouble. The Celestion has blind threaded holes facing the horn flange. I had assumed incorrectly that the CD housing would have through holes - that would have allowed me to put long screws through the driver housing into the flange.
Two studs are enough.
Progress has been slow - I haven't had as much free time as I thought :-\
I have three primed cones built and ready for final paint but have not started cabinets yet.
I decided to wire one up yesterday and take it for a spin - sound is really great! even with the open baffle.
attachment.php
Just got back to my synergy project!
I'm making cabinets out of bamboo. they're based on "tony's cab" design but I've tweaked the dimensions a little
I have the first cabinet (of three) gluing up.
attachment.php
attachment.php
Hah. I’m not done thinking about it. I never did enclose the blue baffle. I had planned to make a quick shell for it an run tests. But later realized I won’t have time. I happened to have a sheet of bamboo and three cabinets sort of fit - so I’m running at it and hoping to have it done before I start a new job.
I’m not sure what to do with the third speaker. I may hold on to it as a mono setup and maybe someday the three will end up in a HT configuration
Hi chicofi
I’d like to build a synergy as well, and Bill’s Cosyne gets nothing but praise and is without a doubt the best documented.
I’ve been using some Oris horns with full range drivers for a while and after one got knocked over recently and damaged I switched them out to an open baffle project that I revised.
It made me realize that although I like the sensitivity, detail and point source qualities of the Oris/fullrange combo...that essentially my head was in a vise due to how directional they are in my modest living room.
I’m not over horns. My DIY system was built around having higher sensitivity speakers. I want to maintain the point source quality of the Oris/fullrange. I need something with better horizontal dispersion I think.
I read the entire SynTripp thread and thought about trying to use it as a basis to design a synergy with B&C 8pe21 and Radian 760neopb drivers I already own.
I’m not sure I have the confidence even after finally understanding Bill’s spreadsheet after reading the pdf and studying it over a couple days.
I started trying to model the 8pe21 in a multi entry in hornresp. I’m not familiar enough with it to get anything that looks right. It doesn’t help that I can’t find any published T/S parameters for the Radians online.
As Bill and you said the Aurasound NS6 8 Ohm drivers are unobtainium...but it is possible to get the 4 Ohm version along with the Gentos and Celestion CD.
Can anyone tell me what adjustments would need to be made in order to use the 4 Ohm Aurasound drivers?
I am not tied to the passive crossover. I would actually prefer to use a pair of the DIY Bi Amp electronic crossover kits I have already purchased from the DIYAudio store. In the mean time I do have a MiniDSP for testing and a few other options.
Sorry, don’t mean to thread jack. I figured since you mentioned the 4 Ohm drivers it was related...plus this is a recent thread. I tried PMing Bill, but his box is full.
Kevin
