An Objective Comparison of 3in - 4in Class Full Range Drivers
Which raises the rather significant question of why you only appear to whine about anything and everything from a single manufacturer.
You cannot provide that information for the large number of other companies I listed, so by definition, you are not in a position to continuously misrepresent one as being worse in this respect than others.
MA data is worse. Compare to Tymphany data for example. Showing a frequency response on a scale going from -10 to +110dB makes any curve look good.
By the way, people arguing that nothing would be wrong with the way the MA data is presented keep the discussion going. If someone would claim that there's nothing wrong with the way Fostex presents their data I would respond in the same way. There is just nobody doing just that.
-I clearly stated I offer no opinion on any manufacturer response data.
-I am not discussing manufacturer response data with you, or anybody else here.
-You complained that MA does not provide sufficient information about their measurement / test equipment.
-Since you claim said information is inadequate, you must now support your implication that it is inferior to those of other manufacturers by providing your detailed information about the equipment employed by Vifa, Tang Band, Fostex, Scan Speak, SB Acoustics, HiVi, Dayton, PARC audio, Jordan, EAD, Supravox, PHY, AER, Lowther, Voxativ, Aurasound, Peerless, Fountek etc. If you do not do so, or claim they are all as bad, then you must explain in detail why you refrain from passing remarks about them, and direct your entire attention to that provided by a single example.
