An illustrated guide to building an F5
Chiptech,
R3 is bad, but the other resistors may not be bad. Many of the resistors are parallel to other resistors or parallel to circuitry that affect their measured resistance when connected to the circuit. The only way to check many of them is to lift one resistor leg to take it out of the circuit before measurement.
When you were biasing the right channel. was the left channel also connected? Did you attempt biasing the left channel? If no, then probably the left channel is undamaged, and comparing resistances between left and right channels is a good way to check for damage to right channel resistors. Also for R5/P1 and R6/P2, check resistance with pot at maximum in one direction and then turn pot all the way in the opposite direction.
Yes it was connected.
I will follow that procedure to test across the board.
Is this to check the pots? My experience to-date is turning them can go on and on, unless that was because of the missed solder point?
The pot clicks at either end of it’s travel. There are 25 turns in between the click at either end. Make sense?
Ok. I have the board off the heat sink on my table and I just went 32 clicks. It still will turn but there is a click after every full turn. So have I traveled all the way to that end? The resistance of R6/P2 is 1.092 ohms. I went 31 turns the other way to a 0.2 ohms reading.
Same results for P1 and R5: 1.089 to 0.2 ohms readings.
If resistors are not damaged, it should read about 0 Ohm at one extreme and 1532 Ohm at the other end.
So R5 and R6 damaged and/or P1 and P2 damaged. Lift one leg of R5 and R6 and measure them, and then also measure P1 and P2 using the pads for R5 and R6.
If R3, R4, R5, and R5 are damaged, Q1 and Q2 may be toasted too.
