So, I've excluded that 5 from the list but the ones you've recomended, the first one I think is a bit too expensive compared to the other ones, the second one is a mono and it need's to be stereo.
Can you recomend any of the other's I've suggested ou anything in that price range (maybe to 10-12$, no more than that)? I'm open to mod them if it turn's them better.
I've seen that the first thing to do is to replace those big caps with a bigger capacitance and better quality, am I right?
The second one I listed is not mono, despite the description. Both of the amps I listed can be run in mono, by shorting out some links on the underside of the board. Both can be 'instantly improved' by adding bootstrap snubbers, after that it's up to you.
Oh, you're right! When I've made the list, probably looked at the title and saw mono so, excluded immediately.
Can you explain what is a bootstrap snubber, please?
Sweet little amp..
Wholesale Brand new Mini HI FI High power 2.1 DC10 18V Digital Amplifier Board 15W*2+30W Class D Amplifier 10000622-in Amplifier from Consumer Electronics on Aliexpress.com | Alibaba Group
Full function module..
Bluetooth MP3 Decoding Board Module w/ SD Card Slot / USB / FM / Remote Decoding Board Module M011-in Electronics Production Machinery from Electronic Components & Supplies on Aliexpress.com | Alibaba Group
8 ohm L/R and 4 ohm sub provides a nice blend. Forget the FM radio part. The amp will destroy it, trust me..
I have a mod to get the noise out of the sub amp section if this might be an option for you..
#OffGridKindaGuy, that amp is a bit overkill because I will not use a SW, also, some of the ones I've posted looks better in construction.
The Bluetooth part, I prefer to use an "inside the case" receiver as I won't probably use USB or mSD card, so, it's a no-go also for aesthetics. Thanks anyway.
What mod are you talking about to reduce the noise?
Perhaps something like this? (I don't understand what an SW is)
TDA8932 2X15W Dual channels wireless Bluetooth Audio digital amplifier board For modified Ceiling mounted bluetooth speaker-in Replacement Parts from Consumer Electronics on Aliexpress.com | Alibaba Group
DC12V TDA8932 Wireless Bluetooth Stereo 2X15W Dual Channel Audio Amplifier Board | eBay
SW, I mean Subwoofer 😛
The TDA8932 produces too much THD+N at about 10W per channel with 12v power supply. I think I'll stick with the TPA3116/8.
Hello!
So, I've ordered the amplifier already (DC 12V-24V TPA3116 Mono 100W Digital Audio Power Amplifier Board BTL Out Amp MO | eBay) and now I need a Bluetooth module.
Anyone with experience? I would like it to transmit battery information to the phone (I have a Xiaomi Speaker that does that)
I've seen these 3 for exemple:
Bluetooth 4.0 Audio Receiver Board Wireless Stereo Sound Module 12V/24V Car | eBay
KRC-86B Bluetooth 4.0 Stereo Audio Receiver Module Sound Board DIY | eBay
1PCS Bluetooth 4.0 Stereo Audio Module Control Chip CSR8635 Stereo Bluetooth | eBay
I couldn't see the difference by CSR8635 or 45, so I dont know what is better to buy.
Any recomendations?
Thanks 🙂
Any recomendations?
Thanks 🙂
What could I benefit with doing that?
I will try to do that anyway as soon as the board arrives. Any generic caps works with that, right?
Any recomendations?
that one! any bluetooth module that
"allows DIY friends without pressure" has to be it!
however my recommendation: I've been down your route many times, so I have had a lot of the DIY fun, but there comes a time when you just want a compact solution which works so rather then messing with step down transformers and connectors and volume controls and boxes I've settled on this
Nobsound NS-10G Bluetooth 4.0 Mini Digital Amplifier Stereo HiFi Power Amp 50Wx2 | eBay
TPA3118, with built in bluetooth, line-in and soundcard.
You really recomend that BT module or just kidding?
I've already ordered the amplifier alone, so, now I need to buy a standalone BT module too. :S
Impossible to know!
Yeah, standalone amp, standalone bt module, stand alone dc converter, stand alone isolator after you find that the dc converter introduces unacceptable noise, second standalone battery after you find that the isolator isn't making it. Its a process.
I've used several of these in portable jam boxes. Full function and the built in speakers are good above ~400hZ. Use the line out to feed your amp. Consider a sub! Both can operate at the same voltage so no need to convert voltages..
Zeepin AV252B Car 1 Din Stereo Radio Audio Player Built in Bluetooth 2.1 EDR Off Preset 18 Stations FM Time Display Autoradio-in Car Radios from Automobiles & Motorcycles on Aliexpress.com | Alibaba Group
Impossible to know!
Yap, that's my objective since I have the speakers, the amp (incoming), a bunch of other things, I will try to do that process. Don't crucify me 😀
Like I was saying, I have the amp (incoming), the speakers, passive radiator, etc.
Missing now is Bluetooth module (and after, the batteries), so I won't buy a full speaker. The fun of it is to DIY the whole thing my way, not buying something done. For that I have a Mi Speaker 2x3w.
Thanks anyway for the suggestion. 🙂
So, I was thinking to buy this one that already come with the buttons. I think It's not bad, right? Bluetooth 4.0 Audio Receiver Board Wireless Stereo Sound Module For Phone Car S | eBay
Looks good Rad, that amp I bought (not received yet) Digital 2.1 Channel Amplifier Board Bluetooth USB Input 50W+50W Stereo 100W im | eBay I sadly just found some Amazon reviews on it, all bad. I am hoping that maybe mine will be lucky. Also, the biggest complaint I have heard about most of these amps is the built in voice that announces power on connection, etc in annoying asian voice according to the complaints. Not that I have anything against Asians(i am married to one) but it would be a nice option to mute that voice.
Exactly, maybe this one I'll receive have beeps or something similar and not the voice. I'll try to program it if that's possible, to change the sounds to something more confortable. Fingers crossed 😀
Hello,
So, it came the amplifier and I've been testing it. It's absolutely amazing the sound of this thing for 5€ +/-. I've connected it to my 100w speaker with 19v power adapter and the result is awesome without any mod (perhaps needs a little more bass refinement).
Is there any chance to add a LED to know when it's on or not?
Also, to get a little better bass, which capacitors do you recommend to use? These are 4x470uF 50V (original??) Sanyo.
Thanks in advance.
Some pictures here just because 🙂
Thanks in advance.
- Class D
- Amplifier for Bluetooth speaker
