Hello everybody!
I started to build my first active speakers.
The elements I going to use:
Scanspeak 6600
Audio technology 18h
Scanspeak 8531
Crossover: behringer dcx2496
I have two options for 6 channels amplifier:
Rotel rmb 1066 or mcintosh mc 440 witch is a car amplifier and nead external power supply .
What do you think ? Rotel or McIntosh?
Thank you
Scanspeak 6600
Scanspeak 8531
Thank you
Rmb1066 is interesting because you can run it is on 6 channel mode and if you want extra umph later you can bridge the channels but only for 8 ohm drivers.
I would consider some of the older Rotel RB models, 870bx for instance, that can be used in stere but bridged for 4 ohms later. But read up on these amps as they do differ in sound. I have two rb850’s bridged and they sound great, if I was going for a three way I would seriously consider adding two more, using the bridged ones on the bass and stereo on the mid and highs.
Thank you
I thought about adding extra amp but my wife told me "don't redecorate my living room". 4 boxes will be to match for her....
The McIntosh can be bridge also..
Have you herded the McIntosh?
Links to the amps
http://rich.homeunix.com/gravely/hubs/mc400 owners.pdf
http://www.rotel.com/sites/default/files/product/manuals/RMB-1066-OM.pdf
Pic
Some pictures....
Some pictures....
4FE27200-959D-46CD-B320-F22EE03ABFFE-272-00000092EDF09062.jpeg45.5 KB · Views: 122
15BEF925-9A01-4588-A9C7-053B9C81B123-272-000000931BF1C2A9.jpeg28.7 KB · Views: 123
D9DBC92F-F86D-4611-B19E-178E974761D5-272-0000008F92265493.jpeg25.9 KB · Views: 121
7206FC7B-860A-4824-8535-66FB001C5F9E-272-00000092F9B1C181.jpeg22.7 KB · Views: 124
6103BF5D-39AF-47A7-A9AB-80B43694C42B-272-0000009309376288.jpeg21.3 KB · Views: 120
F7FE518F-500B-4ADB-B3BC-FBE9F2DA938E-272-0000008FCFF4F307.jpeg33.5 KB · Views: 71
