Amp Camp Amp - ACA
Glad I accidentally got the correct ones. It was not clear from the instructions from Nelson Pass which ones to get. So you don't want quiescent current too low then? Maybe someone can explain what the requirement is and how you figured that out.
Q1 needs to have a Gate voltage of between about 4 to 4.5V to idle at the right current and set the idle voltage at it's Drain to 10V. International Rectifier parts are very consistant, other manufacturers could vary. With R9 at 1K, this means Q4's current needs to be 4 to 4.5mA. At that current, Q4's Gate to Source voltage can't be more than (minus) 4.5V or Q4's gate voltage would need to be below ground (and thus P1 could net be set). The 2SK170 has very high Yfs (transconductance) and the Gate cutoff voltage (Vgs(off)) is spec'd at -1.5V so there is no danger of that unless a different part is used.
If Q4's Idss is less than 4.5mA, it's Gate to Source voltage would go positive before there is enough Gate voltage at Q1. So a Toshiba GR grade part (Idss 2.0 to 6.5mA) might not work in the circuit as designed. An increase in R9 would permit the output bias voltage to be set, but a slight increase in high frequency distortion would result. Conversely, you could decrease R9 if you had a high Idss part and the result would be a smoother high end. The concern would be power dissipation of Q4 would increase. If you have a fist full of GR grade parts, you could run 2 or 3 in parallel.
Does anyone know the status of those beautiful cases for the ACA being built by Hifi2000 that Jason showed us pictures of on March 11? I am really looking forward to them.
Sorry we haven't offered them for sale yet! They got put on hold for a bit while we were working on new modifications for the next batch of 4U and 5U chassis and new bigger, badder, better and F5-T compatible PSU boards. Which are going to be pretty awesome. We're investing in some custom tooling which is going to take the configuration possibilities and space optimization within these chassis to the next level for our DIY construction / configuration needs. We've spend hundreds of hours on that, really. Can't wait to show you some examples.
Being sea shipping that has a very long lead time so we wanted to get that locked and loaded. We really should have a blog for the store or an update thread so we can better keep everyone up to date with what we're doing. Rest assured we've been busy!
That now under control, I spent all day yesterday on the ACA front panels - we're seeing if we can trick up the front panel a bit while keeping it affordable. We're planning on a presale options survey within a week and presale the week after with direct (and affordable) air shipping right after (we've negotiated a special rate with an Italian shipping service specifically for these boxes).
The back panel is sheet metal and the holes are symmetrical. so it can be flipped to make mirror image monoblocks. Is that your question? The chassis's are small monoblocks, ie one channel each, just like the original Amp Camp Amp chassis' so each has one power supply connection. They are not big so if you want a conventional linear power supply you would buy one of the smallish chassis' without heatsinks that we offer, for the transformers and diodes and caps. The front panel on those will match the 10mm thick monoblocks. (Great new PSU PCB coming incidentally) Then have a detachable cord to each monoblock, or heck, have two separate power supplies, in one box or two!
This would maintain the advantage of the ACA with the Laptop supplies- individual supplies for each channel, located away from the amp circuitry.
