American Bass VFL 500.1
When I test resistance with my canadian tire meter, I have over 8mil ohm one direction and 10-14mil the other. None of them seem to be exactly the same. I just tried my fluke meter and everything is OL on it... So I guess its back to installing to card. I have to put one transistor in each bank to see the wave form properly right?
I was going to install the card but decided I better recheck the pads for proper voltages. Now I have 4 readings that are only -80ish volts and they fluctuate -78.x to -81.x vdc.
I don't think that is normal. When the card was in I'm pretty sure I had much higher voltages there. Thats were I got the reading from before. Unless something happened before I removed the card again and found the 2 shorted transistors. Its the first time I've ever had 2 perfectly new transistors I just installed short all 3 legs.
Here is a pic of the current voltages on the output card pads. I sure don't wanna install the card if there is something with those -80volt pads.
With the card installed I have these readings currently (please see pic). The -80volts are back up. rrrrr down I guess.
I installed 1 high and 1 low output per IC. Gave it power threw a current limiter, power on no protect, switched it over to fused power as soon as the relays clicked on to release muting the amp started making a clicking sound from an inductor, after about 5 seconds POW!. The low side fet from U5 blew explosively.
The inductor that seems to be making the noise is in that section. It also seems to have one really dark strand on it (can sort of see from pic).... is there a way to test it?
I'll remove the outputs from that IC and see what voltages I have again on those pins
