Amateur Soekris 1021
DIYINHK's volume control pcb is only compatible with his boards.
To control volume on the Soekris, you may either use a potentiometer (see the dam1021 manual for instructions) or a microcontroller to do more advanced stuff like have a screen and an IR remote, etc.
There also exists a library for control through an RPi.
so using the salas ultra bib was a total failure. apparently i just cant assemble those boards so after months, im still getting nowhere. i need something cheap and ready made or easy to assemble to power the DAC. im so confused. i searched bipolar power supply and i just found some Chinese diy board on ebay. what is a good dependable and cheap solution to power the dac? i have a transformer that gives 15 ac thati can use. if sopmeone can help out with this id appreciate it.
