Alpine PDX1.1000 powers on, no audio (IR2010s HELP)
Pic1 is R9701 with no signal
Pic2 is R9701 with 100hz at volume 35(out of 62)
Pic1 is signal on R9701/2, D9701/2, and both inputs of IC9701
Pic2 is the square wave output of IC9701 up to the 1k resistor R9713
Pic3 is the side of R9713 that connects to Q9701
Lifting D4501/4502 allows the signal at R9713 to pass through unhindered.
Q9701/9702 are currently out of the circuit. The voltages at the pads are:
Leg1 5.01
Leg2 -45.89
Leg3 2.53
Pic1 is with 100hz signal at R9701 at volume 23( that is the threshold where the spikes occur as it is only a flat line at 0v at any volume lower)
Pic2 is at volume 55.
I reinstalled Q9701/9702 and am getting a square wave on Pin1 of IC9702/9704 with D4501/4502 lifted.
