polarity is correct during measurement. Indeed 4A thru 1 bad cap should be the recipy for some serious fireworks (no vent in caps ).
Since my dayjob is rather demanding at the moment it will take me some time to rebuild de psu, luckely the A5 was driven thru a sugden intergrated amp with pre-out it's got so I'm not completely ampless at the moment, although the sound is rather flimsy compared to the Aleph
not been my experience...
...when I've used a meter to measure electrolytic caps, it hasn' t mattered. Perhaps I've been lucky, or maybe the voltage my meter is using is low enough it didnt cause problems. In either case, you are quite right, it could make a difference...
Stuart
Stuart
Ralph,
Could it be the temperature inside the amp that killed a capacitor ?
Or did you use 105 Celsius caps ?
Just after i'd finished my Alephs, i see a dutch DIY' er in trouble
I'm getting a bit scared .......
By the way, it's nice to know you found the problem.
Grtz
Nick
ps : ddiy 2005 ? did i miss a topic
Grtz
Nick
So I rebuild the PSU and there's nothing wrong.
With no resistance to it I get a nice 6A on both side pos/neg.. Voltage is ok to. So that started me wondering.
What would happen if 1 of the connections of the bridges was a bad solder....?
So now it's only rebuilding the complete amp in the case again . Which I now will make a bit more servicable while I'm at it.
Ralph
Ralph
