Aleph J Schematic
Thank you Zen Mod for your quick answer.Was just preparing to drill another hole 😀
I have at hand some kapton tape but is sticky at one side and I`ll want to use this with thermal grease between heatsink - tape and tape - mosfet.From what I read Kerafol Keratherm is better than mica(kapton) but I`ll have to do another order and wait at least 2-3 weeks and to be sincere I am fed up waiting and my budget is pretty limited.
So what do you suggest?(you already did but...not in this situation meaning my budget limitation and time)
+ if you are concerned about thermal resistance, grind the anodising off where you mount the output devices (and/or polish the blank surface right before you mount the insulator/device).
For changing the bias, the whole idea of this DIY endeavour is to get a grasp of what you're doing.
Early on in this thread it has been mentioned (4-eyes, as usual) that the 68Ksomething can be replaced by a lower value and a trimpot to fiddle.
Thank you guys for the tips
I think i will try to grind the surface like jacco says even if the layer of anodisation is very thin I think it will count on thermal resistance.
As for R27 I have ordered multiple values between 70-140K Vishay RN55D...Just wainting for them to arrive.
finished soldering...
