HBarske said:Yes, I could. Do you see any advantage in doing so?
btw - nice thread on Analog Forum 😉
HBarske said:
This is obviously a small world![]()
well - my first foreign language was Deutsche Sprache ......... unfortunately , I haven't much praxis in using it in last decade or so........
anyway ....... Die Ganze Welt ist ein Dorf ......... 😉
Twilight zone, a freshman overhere transforms into a self-appointed expert in his own lingo.
HA-tsjoe
(a shame the powersupply board for the A-J is not divided into individual CRC groups, Scandy way)
HA-tsjoe
I urgently hope you are talking of something I have no idea about - and not me...a freshman overhere transforms into a self-appointed expert in his own lingo.
I'm pretty sure that Jaccovity is talking about mine musings ...... that's sorta usual
- but part in brackets is certainly for you
Not you, Holger, i'm a longtime K&T reader.
I meant the pcb critic, i've been following the analog thread as well.
In general yes: Shorter signal path, the signal only "sees" 1 ( paralleled, hence lower inductance ?) resistor and 2 solder joints instead of 4 in series, and one copper trace less. In this particular position it may not be worthwhile but if it was the primary signal going thru the resistors I would certainly parallel them. In my philosophy every little detail (that I'm aware of) counts but I AM a nitpicker.
HBarske said:Scandy way
iirc, Lars Clausen picked that setup for the PS of his power amp design.
Instead of 8*C-15*R-8*C, 8 times 1*C-2*R-1*C.
Requires adding a 16th R, using a 19.1 Ohm E24 or a 20 Ohm E96 (and swallow an additional 0.2 Volts drop across the CRC)
Much nicer(imo), but a lot more work on the PCB layout.
Referring to the layout from the 11th, don't fancy the fender bender path for a 4 amps current level. (Geschmack Sache)
ya nutz.
where's da pic ?
I'm dumb .
I am afraid I don't get it either.
Current psu setup is 1C (22kµF) - R (0,2 Ohm) - 1C (22kµF) per channel and rail.
No idea what you are talking about...Referring to the layout from the 11th, don't fancy the fender bender path for a 4 amps current level.
Holger's layout for a 2-channel single phase PS board is on page 4 of the thread.
Much more flexible to parts choice, the latest layout choice only allows biggy elko's.
Pictures of the multiple CRC board have been posted (and discussed) on this forum, i'd have to go through my image junk data to find it.
(you could ask Vati-P to post his approval at the German forum, instead of naming the 3 PLF stooges)
[off topic]
Hannes,
ich hab total kein Bock mich mit dir zu unterhalten, und recht gar nicht mit PN.
Die meisten Leute hier haben total keine Ahnüng wehm ich gemeint habe, entweder sie sprechen kein Deutsch oder lesen Holger's Thread nicht.
Meiner Meinung nach habe ich mich sehr Diplomatisch ausgedrückt beim formulieren meiner Ansicht, sogar Holger war nicht im klahren was HA-tsjoe bedeutete.
Und ja, meiner Meinung nach gibt es ein Unterschied zwischen ein Chef-Redakteur einer "gewissen" Magazin und ein Rookie.
Mir gefählt dein Ton genauso wehnig wie es die Leute auf dem Analog Forum gefählt.
In Holger's Wörte : der Ton macht die Musik.
Sich auf dieses Forum zu presentieren als sympatischer NewBee und auf ne Deutschsprachigen als durchsagender Besserwisser, das macht nur ein Spiessbürger.
Gestanden, die Sache mit A'af hat schon ein fauler Geschmack hinterlassen.
"Liebe Grüsse" beeindrucken nur wenn die offenherzig gemeint sind.
Noblesse oblige : in deiner Sprache.
Hannes,
Of course I emailed him for his approval, but asking him to answer directly on the analog forum would have been a nice idea 😉.you could ask Vati-P to post his approval at the German forum
Pardon me for this kind of cheap advertising 😀.instead of naming the 3 PLF stooges
jacco vermeulen said:Holger's .........
HBarske said:
Of course .........
yo , stooges - why don't ya talk serbian, so entire world can understand ya .......... ?
anyway - I prepared 20 x 10KuF + 2 x 9mH/5A + 2x 22V/800VA donut for my never ending Babelfish .
seems that I'll make HP amp before proper biggie one 😉
more caps - better , especially when they are cheap and you can put plenty of them
boiled water , scavenger dream, whatever .......
- Aleph J Schematic
