that means entire Aleph CCS control mechanismus is bootstrapped to output
meaning - it is swinging along with output node , R25/R26/C2 node - way above upper rail , keeping working parameters (almost) unchanged
Yes but why does it have to be so big? In spice the distortion goes down with a sane capacitor value and it brings down the amount of AC current diverting into the cap as well.
if you're talking about C2 (bootstrap cap) - you need to think about lowest frequencies ....
if you're talking about C3 (Aleph CCS modulation path) - you need to think about lowest frequencies
The time constant between C2 and R25/R26 is 0.4/0.2 hertz. Lowest frequency of interest should be 20hz. What am I not understanding?
irrelevant - just remember that , to avoid phase twisting , you need to calc RC constants pretty low
that's good for start , until you really learn what's phase shift/twist
Hello, Bobsburger capacitors modify phase up to one decade past the determined fc. Thats a reason you sometines see way higher capacity that you would allow for your target audio fc.
something is fishy
do what I said in #1894
I got my Aleph J singing today after about couple of weeks and thanks to all guiding me on the issues. The issue was with couple of mosfets damaged because of the heat not being dissipated to the heat sinks. Those mosfets were no properly mounted on the heat sink and hence got damaged. So ordered matched mosfets again and had to wait for some weeks and I received them last week and replaced all the 4 mosfets with proper mounting of new heat sink holes/tapped. This time I used hex screws rather than the usual star screws for mosfet mounting.
I set the bias to 400mv and the heat sinks are manageable and hot to the touch. I think I will not go beyond 400mv bias as the heat sinks may not manage with our tropical climate. Managed to get 0.1mv dc offset on both the channels and after playing for more than couple of hours the offset drifted around 4 to 5mv otherwise pretty stable. The hottest amp build so far 🙂
Congratulations [emoji3]
Sent from my iPhone using Tapatalk
Upload your 'porn' here, share the glory 😀
- Aleph J illustrated build guide
