Aleph J - First Test Issues / No Sound / Blinking LEDs
Reading and commenting in this post, I have an Aleph J in its build stage at the moment so I am taking an interest in this thread.
Correct me if I am wrong.
With no load connected to the amplifier I cannot see a mode of failure from connecting a single rail power supply. OK it wouldn't work but I can't see any component that would be put under duress.
I also said it wouldn't work.
My point is that I can't see why components would fail.
OK, he had a load. Yes, the MOSFETs would be under duress trying to destroy the speaker.
If you get a gate to substrate short on the MOSFETs, yes that could destroy the driver stage.
Zen Mod: I want to make sure I'm taking this measurement correctly before powering up. I have the positive lead of my meter clamped to the collector on Q3 and the negative lead clamped to the V- pad. I can observe between 1R and ~60R between these connection points during the full range of the pot. When you say "minimized", do you want me to set it at the minimum or maximum resistance? I'm guessing minimum - but I don't want to make any mistakes.
Update: I fiddled with R7 trying to see a change in voltage. I'm now able to get to zero; but, unlike the working side, a slight movement of the pot (1/16 of a turn) will change 2-4V. The voltage can be adjusted negative, as well.
R27 will make the output voltage change, but I haven't been able to adjust it to cause a voltage reading across R16.
I'm assuming those are R9, R10, R11, & R12?
Nothing registers with the meter in the 200mv range.
Also of note, the output was 13v when power was turned on again. It falls steadily. I was able to force it down to 0 by adjusting R7 for the test.
There is a smell - of hot electronics, for lack of a better term; but not burning/smoke.
output source resistors, again for ooomteeenth time, are R16,R17,R18,R19
power off
move R7 to 0 ohms, do what I said with R27 trimpot - max it , then power up again, try setting procedure again
R27 for coarse Iq (reading across any of said source resistors) , R7 for offset and fine set of Iq
Zen Mod: THANK YOU! Thank you, so much, for being patient with me!
R7 is very, very sensitive compared to the other side; but I can get close to 0V on the speaker output w/ 354mv across R16.
The voltage on the speaker out is slowly climbing. When I started typing this, it was +.1. It's now -2.1.
